grounding for rear lights
Old Aug 10, 2003 | 04:49 PM
getoutside's Avatar
getoutside
I am bolting some bright backup lights to the bumper on my '95 Ford 250 truck. The factory standard is WAY too dim. Where should I look for a good chassis ground back there?
thanks
Old Aug 10, 2003 | 05:23 PM
HomerWinzlow's Avatar
HomerWinzlow
Bumper, bumper brackets, frame and body itself are all good grounds as long as they are clean of rust or paint in the contact location.
Old Aug 10, 2003 | 08:29 PM
Franklin2's Avatar
Franklin2
You might want to use a relay and some heavier wiring if your lights draw alot of current. The original back-up light switch on the tranny might not last very long with the heavier load, plus your brighter lights will be even brighter if they have their own heavier wire running to the rear of the truck.
Old Aug 10, 2003 | 09:32 PM
getoutside's Avatar
getoutside
I strung a separate wire under the truck body to the back for the lights - and separate switch. But drilling a hole for the self tapping screws included with the lights looked like an arduous job. The bumper or frame will do it using these self tapping screws? Guess I'll need that BIG drill.
Thanks for the help.
dieselsmoker
6.4L Power Stroke Diesel
May 26, 2013 10:32 AM
rmalottwtes30
13
Apr 8, 2008 05:34 PM
Big Red
Nov 4, 2003 09:07 PM
Big Red
Electrical Systems/Wiring
Nov 4, 2003 07:58 PM
hbrown
Feb 5, 2002 02:56 PM
