replacing vacuum lines
Old Feb 16, 2016 | 10:27 AM
  #31
scrobbie's Avatar
scrobbie
Originally Posted by scrobbie
The above image was a practice pic to see if i kind of still new how to post them or not
Also guys I removed the AIR pump years about 3 years ago due to a bad bearing and what i did was block the vacuum line from it put a 1/4 inch bolt in there i removed the steel barbed pipe on the right side beside the exhaust manifold then the hose it was connected to, behind the engine i shoved a plastic bag in that hose. But the vac lines are still hooked up to thr TAD and TAB solenoids do i still need those? If not what how do i bypass, or get rid of them? And what else can I get rid of in the AIR system? Thanks again for all your guys help
Old Feb 16, 2016 | 11:49 AM
  #32
fordf350man's Avatar
fordf350man
I bought a smog pump delete pulley off of summit. Its made for the 302 but fits perfectly fine on my 351. You will need to leave TAB and TAD hooked up electronically to not have a CEL but just cap the connections at the intake and unhook from TAB and TAD. If not using air pump system you do not need vacuum lines to it. You can leave the connections on the TAB and TAD uncapped or cap them if you prefer. I can't remember but I think I ended up not needing to run a vacuum line to the tin can (mines plastic in my 94).
I put bolts in the back of my heads where the smog tubes hook up. I heard you are supposed to use a certain length bolt but I just used what fit but not too long and its been fine going on 2 years now. If you really want to do it right you would want to replace the cat as the stock ones are designed to run with the smog pump but its supposedly not necessary to replace the cat although I did since I had the ugly torpedo cat I wanted gone anyways. The smog pump only works while the truck is warming up from my understanding.
Old Feb 16, 2016 | 12:01 PM
  #33
scrobbie's Avatar
scrobbie
My cats are there but gutted so no there not there just for looks no emissions check here in Missouri but back to the bolts on the back of the heads i cant seem to find where abouts they would go? Cant find any images either, maybe i just havent looked hard enough. I think they said they are 5/8-11x3/4 one guy even said he used 1" and used 2 washers. As far as the TAD and TAB u just cap off the top port I think? Oh and i already ordered my silicone vac. lines from the link you gave me thanks again! Any more help on where those bolts go if possible is very appreciated!! Cheers man thanks
Old Feb 16, 2016 | 12:10 PM
  #34
scrobbie's Avatar
scrobbie
Also I have to vac. Canisters on on the right side and the other in front of the coolant and windshield wiper reservoir to store vacuum! Both metal but dont leak yet and i just bought a shorter belt no pulley though which works good at least for mine.
Old Feb 16, 2016 | 02:19 PM
  #35
chrismd188's Avatar
chrismd188
Where did you get a 25' roll of hose all i can seem to find is a 50 or like a 10' pc and autozone sells it for 1.39 a foot at least the 50' on Amazon for around 17.00 dollars i just dont wanna have a whole roll of extra like that thanks again
I got it at autozone,if your not in a big rush you could order it online cheaper, think it was like $26 for the roll,
Old Feb 16, 2016 | 02:26 PM
  #36
scrobbie's Avatar
scrobbie
I ordered 26' of silicone vacuum hose online with the link f350man gave me above it was 99 cents a foot thanks for the input my friend believe me all is welcome!
Old Feb 16, 2016 | 06:40 PM
  #37
scrobbie's Avatar
scrobbie
do any of you guys know where the 2 5/8 bolts go in the back of the heads on a 5.0 after removing the smog pump im sure its hard to see especially up from the top of the motor? And the best way to get to them? Thanks again guys 4 all the help! I mean it!
Old Feb 19, 2016 | 09:55 PM
  #38
scrobbie's Avatar
scrobbie
I finally got my silicone vac hose in the mail will soon be replacing the lines will keep you guys posted thanks again folks! And cheers!!
Old Feb 20, 2016 | 09:32 PM
  #39
ChRoNo16's Avatar
ChRoNo16
I just used this guide this last weekend it took 20 feet of 5/32 vacuum line, and about an hour to do- works great
Replace Plastic Vacuum Hoses with Rubber - Ford Bronco Forum
Old Feb 20, 2016 | 10:17 PM
  #40
scrobbie's Avatar
scrobbie
Replace Plastic VacIm uum Hoses with Rubber - Ford Bronco Forum
yeah i seen that one myself. I still havent seen where im going to need the tees yet though? Anywhere it looks like there would be a tee i have check valves i guess i will find out where they are when i replace the lines thanks again!
Old Feb 21, 2016 | 02:02 PM
  #41
scrobbie's Avatar
scrobbie
Did any of u guys use wire loom to protect your vac hoses, After replacing? If so what size, if you remember what they were lol thanks again for the help Robert
Old Feb 21, 2016 | 05:57 PM
  #42
ChRoNo16's Avatar
ChRoNo16
I used the vacuum t's up by the ports i think its injector sensors? drivers side towards the back of motor on top 2 black boxes plugged in, you end up having to make 2 lines into 4 connections there.
I dont have my truck tonight its off having the front end looked at or I would take a picture for you.
Old Feb 21, 2016 | 06:12 PM
  #43
scrobbie's Avatar
scrobbie
Ok thanks i did use on tee on the passenger side because there were two red plastic hoses connected together one to the intake, the other to the egr solenoid the one line went to the vacuum reserve up to the port on the left side of the reserve.
Old Feb 21, 2016 | 06:20 PM
  #44
scrobbie's Avatar
scrobbie
Also i dont have the smog pump anymore can i delete the vacuum lines to the TAD and TAB solenoid as i will not be hooking the smog pump back up. Then just cap off the hole on the vac reserve, on the passenger side of the truck, where the black vacuum hose goes to the TAD and TAB solenoids any input, anyone? And thanks again to all!!
Old Feb 21, 2016 | 06:28 PM
  #45
scrobbie's Avatar
scrobbie
This is the reseve im speaking of im going to get rid of the red hose soon lol
