Power window repair
Old Feb 14, 2016 | 06:00 PM
gman97005's Avatar
gman97005
Power window repair
drivers side window came off track and fell to bottom of door so i propped it up with a stick and found a guy on craigslist to replace all window related hardware including track and motor for $185, he will be here at 10am tomorrow morning so i will take pics and try you show you what's involved in the repair..
Old Feb 14, 2016 | 07:54 PM
jimbomitch's Avatar
jimbomitch
Sounds good, I've never had any occasion where I had to go into one of my doors, knock wood, but it's nice to know what's involved if necessary.
Old Feb 14, 2016 | 11:21 PM
vettex2's Avatar
vettex2
I haven't done a van in ages.
Typically, they are much easier than cars and can be done in under an hour.
Old Feb 15, 2016 | 04:33 PM
gman97005's Avatar
gman97005
His work van..
the broken part as can be witnessed by loose cable..
work work work
work work work
work work work
all done with ensolite covering the door panel and woofer installed, if you use a speaker baffle like mine be sure to cut out the bottom of the baffle so the speaker vents to the door otherwise you will have poor bass response..
Both his labor and the part are guaranteed for life so if it breaks again it's no charge to fix it..
Old Feb 15, 2016 | 09:54 PM
jimbomitch's Avatar
jimbomitch
Well done. That seemed like a decent price being he did it at your location.
Old Feb 16, 2016 | 05:58 AM
JWA's Avatar
JWA
I'm also in the auto/truck glass biz and for us this is a relatively easy swap. I use OEM parts, most likely he used an imported aftermarket part which explains the fair price. This sort of repair is common especially on the driver's door as its in almost constant use every time any vehicle is driven.
The nature of that regulator mechanism makes it slightly prone to the lift cables breaking and there's no re-habbing or repairing them once that occurs---straight replacement is the only cure.
Glad you're back up and running now----that can be one huge inconvenience when it happens.
motorcarmike
Jun 11, 2021 10:11 AM
Firewood Bandit
Feb 6, 2018 03:22 PM
hharris8
Dec 9, 2016 03:30 PM
ljt motorsports
1983 - 2012 Ranger & B-Series
Oct 10, 2010 12:41 PM
Tees77f150
Mar 29, 2010 08:25 AM
