The main thing is you got them Chad, I had a couple tough ones too but it's a lot cheaper to repair them than buy new ones, especially now with our dollar.
Both my bottom hinge pins were broken,they were sized solid so I drilled them out,I found a tractor pin that was a bit bigger,drilled the holes bigger and welded the head to the hinge mount, total cost was under $5 for both.
4 of my spare hinges were seized to the point where they looked welded. Tried drilling them out and only made the channels crooked. So they were garbage.
Yep there very fun to drill!! My holes were off by a bit but not enough to make a difference
