Dead Battery
Old Feb 14, 2016 | 10:44 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Dead Battery
Went to go for a drive and used the remote start. Nada. Thought that was weird, opened the garage and stood there and tried to use it again, no dice.
Door locks wouldn't open so I had to use the back-up key to open the door. No lights or anything.
DMM showed 5.5 volts at the terminals.
I have no aftermarket accessories of any kind. What could have caused my battery to drain overnight?
Josh
Old Feb 14, 2016 | 12:33 PM
tvsjr's Avatar
tvsjr
Most likely that you left something on. Less likely that the computers didn't shut down properly.
If the battery was down to 5.5V, it's extremely likely that at least one cell has been reversed. I'd regard that battery with serious suspicion.
Old Feb 14, 2016 | 01:59 PM
jr105's Avatar
jr105
Could be a defective battery. It happened to my wife's new car a couple of years ago.
Old Feb 14, 2016 | 02:43 PM
Bullitt390's Avatar
Bullitt390
I'm not entirely sure if something was left on. When I came home yesterday nothing was out of the ordinary.
I charged the battery for 2 hours and went for a 2 hour drive. I'm going to let the battery sit an hour or so and load test for verification.
The only thing I can truly think of is Sync powering up when one of the doors was opened last night. That caught me off-guard a couple weeks as I was dinking around in the garage later and heard the radio playing.
Josh
Old Feb 14, 2016 | 03:25 PM
senix's Avatar
senix
Had the same thing happen in our Lincoln. It is a 2015. Had maybe 3-4K on it. Didn't drive it for a day and it was dead.
Jumped it and took it in. Full diagnostics revealed nothing.
Been fine ever since.
Old Feb 14, 2016 | 03:31 PM
Bullitt390's Avatar
Bullitt390
Went ahead and load tested the battery with my digital load tester.
730 amp OE battery, results showed 750 amps @ 12.88 volts.
Alternator put out 14.7 volts during the 2 hour highway cruise. I can load test that myself at work tomorrow, but I am not overly concerned with the health of the alternator amperage.
I am thinking Sync may have powered up and then proceeded to drain the battery...... more investigation to follow
Josh
Old Feb 14, 2016 | 03:32 PM
GlueGuy's Avatar
GlueGuy
5.5 volts indicates extreme discharge. Anything lower than ~~ 10 volts probably is a damaged battery that will need to be replaced. Most likely something was on, or at least didn't get shut off properly.
Get it charged up, then set up a test with an ammeter. It will require disconnecting one of the terminals of the battery, and inserting the ammeter in the circuit (unless you have an ammeter that can use a hall-effect detector).
DON'T try to start the truck or do anything other than seeing what the parasitic load is (or isn't). With everything turned off, it should be a small fraction of an amp; maybe 200 milliamps at the most.
If it's over that, then you can by trial and error remove the fuses for different circuits until you find what circuit is pulling all the current.
Old Feb 14, 2016 | 03:34 PM
senix's Avatar
senix
I suspicion one of the modules didn't shut down. Just a guess.
Old Feb 15, 2016 | 07:05 AM
Gary Lewis's Avatar
Gary Lewis
I had something similar with a new (500 miles) Murano 4 years ago. Turned out to be the Body Control Module randomly turning everything on. The dealership had to keep it a week to catch it doing it, and even then they had to put it in a dark bay so it would be obvious.
I hate seeing that our trucks can do that as well, but I shouldn't be surprised as anything electronic can. Good luck finding it. I'd be paranoid.
Old Feb 15, 2016 | 07:09 AM
senix's Avatar
senix
I have not worried about it since. I carry a battery jumper box for awhile. Finally just took it out.
Old Feb 15, 2016 | 07:18 AM
Bullitt390's Avatar
Bullitt390
I think I know what happened...
So, Saturday I get home and lock the doors. Later I went and with the smart key in my pocket I opened the passenger door to retrieve a new shower head. I "think" everything powered up at that point like I was going to start the engine and drive away.
Which was the similar scenario a couple weeks ago when I caught the radio was playing well after I had gotten home.
I notice Sync behaves different if you open the door with the key in your pocket versus using the fob to unlock the doors. At least mine does.
Josh
Old Feb 15, 2016 | 07:25 AM
senix's Avatar
senix
You might be onto something there. We were asked if we keep the fob in our pocket and how far away we were to the SUV. Thoughts were it was being powered up. Not the case but we do go out and get stuff and just touch the handles and it will open.
Sometimes we don't lock it right away.
Old Feb 15, 2016 | 07:32 AM
Gary Lewis's Avatar
Gary Lewis
Mine doesn't power everything up in that scenario, and I don't think it should. So, if yours is then I would think it can be proven and fixed.
Old Feb 15, 2016 | 07:34 AM
senix's Avatar
senix
will power ambient lighting , mirrors and a host of other things. It is a Lincoln so there is a lot of gadgets.
Old Feb 15, 2016 | 07:42 AM
Gary Lewis's Avatar
Gary Lewis
Actually, I meant our trucks. Mine doesn't bring Sync on unless I press the Start button w/o depressing the brake pedal.
