Too Tight?
Old 02-14-2016, 08:05 AM
jack orchard's Avatar
jack orchard
jack orchard is offline
Too Tight?
I am getting ready to fire up my 300 rebuild. Even though I checked clearances during assembly, it seems a bit hard to turn over using a breaker bar on the crank pulley.
Does anyone have a ballpark idea of how many foot pounds of torque would be required to turn over a stock rebuild without plugs installed?
Thanks.,...jack
Old 02-14-2016, 12:32 PM
fordman75's Avatar
fordman75
fordman75 is offline
Thanks.,...jack
Did you set the ring end gaps?
Old 02-14-2016, 12:44 PM
jack orchard
I think I did, but I don't remember. It was a year ago. It is bored .020. If it is too tight, that is probably the problem. The crank and cam spin freely without pistons. I just don't how tight is too tight. Thanks for your reply.,...jack
Old 02-14-2016, 01:12 PM
fordman75's Avatar
fordman75
I don't have a # for rotating force required.
I almost hate to say this. But if you are worried about it you are better off tearing it back down and rechecking everything. If it's too tight and you try to fire it up you could do a lot of damage.
Old 02-14-2016, 06:52 PM
The Frenchtown Flyer's Avatar
The Frenchtown Flyer is offline
Thanks.,...jack
With the earlier thick rings and strut pistons about 20 - 25 lb ft.
With the later thin metric rings on hypereutectic pistons significantly less.
Old 02-14-2016, 08:00 PM
jack orchard
Thanks, FTF. I think I am right at 20-25 lbs. I have the old type pistons/rings. This is the only 300 I have assembled. I was concerned because it seemed like more drag than the 289 and 302 V8s I am more accustomed to. Thanks to all.,...jack
Old 02-14-2016, 11:07 PM
seattle smitty's Avatar
seattle smitty
seattle smitty is offline
Flyer, "platform-honing" wouldn't alter those figures significantly, would it?
Old 02-15-2016, 09:09 PM
I think plateau honing may decrease t.t.t. but I have no data to support it - that I can remember. At any rate it would reduce running friction.
acl9865
10-14-2017 07:06 PM
schweinhaus
03-22-2015 10:57 PM
1st Restore Project
04-21-2008 07:40 PM
Mid_Mo_F100
11-02-2005 08:41 AM
tweakingit
09-17-2003 12:07 AM
Quick Reply: Too Tight?
