cab to bed alignment question
Old Aug 10, 2003 | 01:58 PM
Longstreet's Avatar
Longstreet
Question cab to bed alignment question
I'm looking at a '72 F150 for $750,00. Enigne seems good, interior is decent for a 30 year old truck, and the body is o.k. except for one thing. The bed doesn't line up to the cab properly. If you sight down the fenders, rather than forming a straight line the trim seems to break uphill at the bed. I've seen this quite a bit on some of these older Fords, the bed never seems to line up quite right. I'm wondering if this is normal. Could the frame be bent? Is there a way to tell on the test drive, or do I need to go to a mechanic? Thanks for any advice y'all can give.
Old Aug 10, 2003 | 02:18 PM
460 Crew's Avatar
460 Crew
Check all the mounting points on the cab and bed for sagging metal or the rubber bushings on the cab,if all is fine mabey could be the frame but their pretty tough you might just have to shim the bed up to match the body lines. 750 bucks is a deal I whouldn't pass it up.
Old Aug 10, 2003 | 04:14 PM
Ironbelly's Avatar
Ironbelly
The bed of my truck is slightly misaligned from hard use by past owners. It was used a wood cutting truck, so the floor of the bed is a little beat and a little bent, but fixable. That could be another reason if not both.....750 bucks is a good deal.
Old Aug 10, 2003 | 06:24 PM
willowbilly3's Avatar
willowbilly3
One corner is a little low on my 72 due to the dufess that installed the dual tanks cut away the reinforcing rib on that side. I still hate seeing those tanks with the little aluminum doors hacked into the side of the truck.
By the way you must mean a F-100 or 250 not F-150 since the 150 didn't come along until 76. Common mistake. And a common problem with the alignment.
Old Aug 10, 2003 | 07:32 PM
BB's Avatar
BB
'75
Old Aug 10, 2003 | 08:09 PM
willowbilly3
A 75 F-150? could be but I was buying new Ford trucks back then every year or so and I seem to remember the 76 as the first 150, but I've been wrong before.
Old Aug 10, 2003 | 10:54 PM
460 Crew's Avatar
460 Crew
My new bed going on my crewcab has those stupid tanks with the doors on them I'll be chopping those out and welding new body back in there and just using a 50 gallon in bed tool box fuel tank combo. They really weren't practical concidering what gas guzzlers were in these trucks. You whould have thought they whould have put the spare in the bed and a tank inbetween the frame standard!
jeb79
Jan 3, 2018 12:41 AM
Zack1973f250
Texas Chapter
Dec 20, 2016 06:51 PM
sam_stach
Oct 17, 2015 10:30 PM
ecoboostguy
2009 - 2014 F150
18
Nov 22, 2012 08:15 PM
prettyray
Oct 12, 2009 03:27 AM
