Every seen anything like this?
Old Feb 13, 2016 | 10:57 AM
87_f150_5oh's Avatar
87_f150_5oh
There's this heat sink on the passenger fender well on my 84 f250 6.9. It had a wire running from the alternator to the middle terminal. Then the top terminal went back to the heavy gauge fusible link wire that would usually just bolt to the positive terminal on your alternator. And the bottom one went through a circuit breaker to a heavy gauge wire that dead ended along the drivers frame rail. It acts like a diode because it won't let voltage to the alternator with the truck off but it will let current flow through to the batteries when the truck is running. Any ideas what it was for?? I cut it out and hooked it up originally and all is well so far...
Old Feb 13, 2016 | 11:18 AM
Hound Dog Lew's Avatar
Hound Dog Lew
It's been years, but it looks like the setup I had to charge the auxiliary battery in my van.
Old Feb 13, 2016 | 11:23 AM
kr98664's Avatar
kr98664
That looks like an aftermarket isolator for dual batteries. The second battery was probably located in a camping trailer, hence the wire running along the frame rail.
Old Feb 13, 2016 | 11:25 AM
87_f150_5oh
Ahh that'd make sense! With all the crimp conectors they used I was getting almost a 2volt drop between the alternator and batteries so I soldered everything back to factory.
peter_x
32
Apr 22, 2024 09:16 AM
bucks77ford
Apr 10, 2014 09:51 PM
Quick444
Sep 26, 2010 10:14 AM
afinepoint
Electrical Systems/Wiring
Aug 27, 2009 07:27 AM
newblder
19
Aug 21, 2008 08:29 AM
