Electrical trouble shoot
Old Apr 10, 2014 | 12:21 PM
bucks77ford's Avatar
bucks77ford
Alright, I don't have a problem persay, but I am just trying to straighten out some PO wiring that was sort if a mess with my 75 supercab. At one point it had a dual battery setup and when I got it, the battery isolator was still there but everything unhooked. What I have now is a wire from the batt post on the alternator hooked to the batt side of the solenoid directly. The heavy black wire that originates from a fuse link and travels down to the alternator into a rubber loom containing the FLD and SAT wires was cut and lenghtened to what I assume was hooked to a battery isolator. I just had it rolled up and taped until I could figure out exactly what was going on. I assume that I should eliminate the other wire from the batt post in the alternator to the solenoid and just reattach the factory heavy gauge wire to the batt post on the alternator to make things right. Just making sure this is correct. I am not going to use any sort of dual battery setup.
Old Apr 10, 2014 | 12:48 PM
fmc400's Avatar
fmc400
MSEE
I'm having a little trouble picturing in my head what the PO left, but at the end of the day, you'll want to make sure the alternator output runs to the battery side of the solenoid through a fusible link. The alternator output also needs to branch off to run to the 'A' input of the regulator. This happens in molded junction in the factory harness.
If you have an ammeter instead of an ALT light, there's also a parallel tract between the alternator output and battery that runs up to the gauge.
Old Apr 10, 2014 | 02:21 PM
bucks77ford
The black wire with the yellow butt connector is what was cut
Old Apr 10, 2014 | 09:51 PM
bucks77ford
Here is some more pics starting from the solenoid and working down to the alternator. I am pretty sure I have I figured out.
Here is the back of the alt. The PO ran a separate black wire from the batt post to the solenoid and the other black wire was cut and lengthened to go somewhere.
firerescue9
Aug 30, 2013 04:59 AM
rbaruffi
Oct 25, 2011 07:31 AM
rbaruffi
blue52f1
Jul 1, 2005 10:05 AM
oldesailor
May 8, 2004 10:11 PM
