Stalling Out
Old Aug 10, 2003 | 01:33 PM
Razur's Avatar
Razur
Angry Stalling Out
HELP!...Anybody know where the Fuel Pump Relay is on a 2000 Explorer XLT?...Won't stay running...will start but immediately dies whenever gas pedal is released. Any ideas? has 79k miles.
Would be grateful for any advice.
Razur
Old Aug 10, 2003 | 03:12 PM
Opera House Works's Avatar
Opera House Works
Stalling Out
If it stalls when you take your foot off the gas. IAC controls minimum engine rpm. Most engines will stall if this becomes electrically disconnected. Usually located on the side of the intake manifold. Try tapping it, it may have a stuck valve.
Old Aug 10, 2003 | 07:36 PM
Razur's Avatar
Razur
Stalling Out
Thanks for getting back to me!..Gonna run right now and see if i can locate IAC as you said....man I hope that;s it...you mentioned that it may have come undone or disconnected...that mean it uses some sort of wring harness?...anyway..gonna check it...if i can find it and tapping it works...may your well bring forth your favorite ale from now until the end of days!!!!
Old Aug 10, 2003 | 07:50 PM
Billy177's Avatar
Billy177
Stalling Out
thing happened to me just unplug the battery for 15min and wala
Old Aug 10, 2003 | 08:04 PM
Razur's Avatar
Razur
Stalling Out
Thanks Billy, gonna try both suggestions....as soon as I can get my wife to stop freaking out about holding a flashlight while the mosquitos are eating us alive...
Old Aug 12, 2003 | 06:09 PM
jackiedc7's Avatar
jackiedc7
Stalling Out
u take operas advise these air idle controls are known to stick open or leak needs replaced if dirty jack
Old Aug 13, 2003 | 01:45 PM
Razur's Avatar
Razur
Smile Stalling Out
Kudos to Opera,
The IAC was in fact the culprit. It was hidden under a plastic cowel
right in the center of the manifold. By the time I found it i was pretty pissed off, so it took all my control not to smack the damn thing into scrap metal...I didn't..and a few love taps got it working again.
Went to an auto parts store and got some intake and throttle cleaner...cleaned it up and hopefully added a little more life to it.
Thanks also to Billy and to jack for their responses as well. I'm not much use under the hood than a curious spectator, but I am truly grateful for your expertise and generous time.
You saved me a heap a dough, and being recently laid off, I needed a break in fending off another uneccessary bill.
I send you all a cyber -beer and a real toast ! Truck is back on the road, and now, if I can only get my teenage daughters from using it, I might take it out for a victory lap.
Again, many thanks
Razur
Old Aug 13, 2003 | 02:10 PM
CobraXP's Avatar
CobraXP
Stalling Out
rotflmao...
Welcome to FTE Razur!!!
Razur - looks like you did good. Opera and a lot of others know their stuff when it comes to Explorers...
Stick around - they will make you a genuine mechanic before it is over!!!
I am like you - just a spectator... - and don't let any of them here tell you different...
