460 4 speed Starter Question
Old Feb 13, 2016 | 06:50 AM
F.X.5's Avatar
F.X.5
I've done countless hours of research. Still don't have a definate answer. I'm running an external balance 460 with a 180 tooth flywheel. Behind that is an external mount slave cylinder aluminum bell housing from an 80s Ford. Behind that is a NP435 4 speed.
I have room to run a full size starter with fenderwell exit headers. I'm not sure which starter I will need. It's been a while since I did the research (got frustrated and worked on other things) but I remember running into either a 9 or 10 tooth starter. I'm not sure if that was the only variation or not.
If you have a direction in which I should be pointed. It would be greatly appreciated. Really don't want to damage my brand new flywheel with the wrong starter choice. Thank you.
Old Feb 13, 2016 | 07:39 AM
turbo2256d's Avatar
turbo2256d
Converted my 86 dually from a T19 to a ZF 5sp. Dont think I changed flywheel years later installed Hooker headers. for more clearance used a manual trans factory ford mini starter from a newer model 460.
NP435Bronco
15
Dec 1, 2025 09:45 AM
Dalton12316
Mar 13, 2017 05:06 AM
puck1980
Aug 10, 2011 10:59 PM
monte54
Jan 1, 2006 08:42 AM
hillbillyk
Sep 21, 2001 04:46 PM
