Engine Problems-- Hottest Spark Plug?
Old Feb 12, 2016 | 11:08 AM
63flareside's Avatar
63flareside
So I got this truck a little over a year ago. We have had problems with it ever since. It was mostly stock. We went away with the 2 barrel and all the emissions garbage. It now has an aluminum 4 barrel intake with an edelbrock carb. Rebuilt the Carb. Put a new distributor in it. Gave it all new plugs and wires. Just recently replaced the fuel pump. put a better fuel filter on it. Checked the timing a few times seems to be ok. 7 of the 8 cylinders have good compression. Checked the oil and it seems to have a gassy smell. It is currently my daily driver but if it continues to keep running worse it probably won't get driven much anymore. What would you guys recommend for a hot spark plug to run in it to?
Old Feb 12, 2016 | 12:29 PM
Filthy Beast's Avatar
Filthy Beast
You didn't say what engine you have, what Edelbrock - (1405, 1406?), etc, or if you're burning oil. The compression test (wet/dry) should have told you if you have any blow-by in that one cylinder - ring problem.
I wouldn't try a hotter plug until you do the following:
First off, change the oil and filter, pronto! Oil & gas don't mix well and the gas will wash the cylinder walls, berrins, etc, basically wreaking havoc on yer engine.
Second, the cause of that illness is probably because Edelbrocks don't like more than 5 - 5.5 lbs of fuel pressure. Stock Ford pumps put out somewhere in the range of 7 (+,-)lbs. Check yer fuel pressure and if it's too high for the Eddy, try and get a fuel pressure regulator - Holley makes about the best ones around.
Too much fuel pressure would let the gas would run by the float's needle valve, through the carb and into the intake, creating a way rich mixture. When off, the excess would drain down into the engine, giving the oil a gas/oil smell.
Third, it could be the fuel pump has a hole/crack in the diaphragm, letting gas get into the engine. I know you said it's new but new stuff has been known to be junk, too.
Old Feb 12, 2016 | 10:27 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on what he said, and very well said there FB.
Old Feb 13, 2016 | 07:38 AM
Filthy Beast
Thanks, Rich.
Tryin' to catch up to you.....Bwahaha
Old Feb 13, 2016 | 07:51 AM
tabascom16's Avatar
tabascom16
Have you ever pulled the spark plugs to check the color to see how your air fuel mixture ratio is? Rarely can you just take a carb out of the box, slap it on an engine, and expect it to run perfectly.
If your gas is smelling gassy you might be running rich. Your spark plugs will be coated in a black soot, if not even have a oily/tar like coating.
Old Feb 13, 2016 | 08:05 AM
77&79F250's Avatar
77&79F250
Originally Posted by Filthy Beast
Thanks, Rich. Tryin' to catch up to you.....Bwahaha
Its not a race, we are all just happen to be moving in the same direction (the garage). lol
Old Feb 13, 2016 | 09:18 AM
Tedster9's Avatar
Tedster9
Don't need a hotter plug, you first need to adjust carburetor in terms of float height, proper jetting, and idle mixture settings, ignition timing, etc. Classic mistake. Ask me how I know.
9 times out of 10 the stock plug heat range is just about perfect. Plugs are "read" by observing the color of the ground strap and base ring. The insulator not so much, but it's important too.
jmustangs60
Oct 2, 2018 09:05 PM
cliffordingles
22
Jan 3, 2011 02:02 AM
mercury_kid
Jun 6, 2008 10:36 PM
coyoteguard
Nov 25, 2004 05:38 AM
Goffjb
May 23, 2004 05:51 PM
