Engine Wont Start...
Old Dec 31, 2010 | 02:30 AM
cliffordingles's Avatar
cliffordingles
truck is 86' f250 with a 351w. ive replaced the carb the coil and the brain box. the cap and rotor, spark plug wires, and spark plugs are pretty new but the truck sat for some time before i bought it. i dont know why it wont start. its making me pretty angry. someone please help me lol.
Old Dec 31, 2010 | 09:03 AM
ctubutis's Avatar
ctubutis
With the engine off, take off the air cleaner, look down the throat of the carb and fully open
the throttle with your hand, you should see two strong-looking streams of gasoline being
squirted.
Pull a wire from a spark plug, put it on a screwdriver and hold it close to a ground while you
have someone try and start the engine, you should see a strong, blue spark as that cylinder
tries to fire.
Old Dec 31, 2010 | 03:45 PM
cliffordingles
thank you, and yes ive looked and seen the fuel squirt. its good. the spark is good. but now another problem lol. the engine oil is full of gas... im draining it now and letting it sit with the oil filter and drain plug off to help evaporate more of it. i dont know why it would have gas in the oil though... any ideas? again, thank you for the reply!
Old Dec 31, 2010 | 04:41 PM
GLR's Avatar
GLR
Lots of gas?? probably fuel pump leaking. It's possible that enough gas got around the piston rings so as to lower the compression. It wouldn't hurt to pull the plugs and squirt a little oil into the cylinders, then turn the engine over a few times before replacing the plugs. Do this after finishing the oil change. While fuel pump is off see (feel) how much slack there is in the timing chain. The cam gear is steel so you don't have to worry about the nylon gear problem. I think I got the P/S pump out of the way for easier fuel pump access, (also installed an inline fuel filter)
Old Dec 31, 2010 | 05:06 PM
Franklin2's Avatar
Franklin2
If you have been messing with this thing a long time, and the carb has been flooding the engine, that could be where the gas is coming from, and also would be the reason it won't fire, it has fouled the plugs.
If the carb is not pouring the fuel into the engine, then yes, the fuel pump can also leak into the engine.
Old Dec 31, 2010 | 06:45 PM
ctubutis's Avatar
ctubutis
I had a fuel pump leak into the crankcase not real long ago, it was even relatively new and
only around one year old:
https://www.ford-trucks.com/forums/7...crankcase.html
Old Jan 1, 2011 | 04:32 AM
cliffordingles
the carb seems to work fine... i guess it could be flooding. im not really pumping gas into it but there is some standing fuel when i look down the carb and see the bottom of the manifold.
Old Jan 1, 2011 | 08:54 AM
Franklin2's Avatar
Franklin2
There should never be liquid fuel below the carb. I would pull the sparkplugs after you get the oil straightened out, and see if they are wet and fouled with fuel. If they are, you may need to get new ones.
Old Jan 1, 2011 | 11:05 AM
GLR's Avatar
GLR
Liquid fuel below carb?? after pumping probably ok. No pumping probably power valve in carb.
Old Jan 1, 2011 | 04:11 PM
cliffordingles
spark plugs are fine. i guess i could change them anyways though. at this point im just throwing parts at it.
Old Jan 1, 2011 | 04:20 PM
ctubutis's Avatar
ctubutis
I thought your plugs were fairly new.
Get a remote starter switch to hook to the battery & solenoid, peer down inside the carb as
you turn the engine over and see if you can find from where these puddles are originating.
Are your plug wires installed correctly. Is the rotor installed. Does the rotor turn. What
happens if you spray a shot of ether (starting fluid) into the carb as you try and start it. Is
the output pressure & flow rate of your fuel pump OK.
I would look at those things before I began throwing parts at it.
Old Jan 1, 2011 | 06:50 PM
cliffordingles
the plugs are pretty new. is there a way to check to see f the fuel pump is leaking into the crankcase? my next step is to take my new carb apart and check it all out. readjust the floats and check the needles and seats. just to let everyone know. i did read the whole thread about the fual pump leaking into the crankcase. my truck is also sitting on a slight down hill slope. im thinking it might have happened to me also but not sure.
Old Jan 1, 2011 | 06:55 PM
cliffordingles
also, everything is sparking and rotating correctly. im thinking is a massivly over fueling issue... anyone have an edelbrock carb that can tell me how they exactly hooked everything up and the amount of turns on the ideler screws. anything else for the carb? my carb is 4 bbl 600 cfm electric chock. i forget the model number... lol.
Old Jan 1, 2011 | 07:19 PM
Engine126's Avatar
Engine126
Happened to mine
Just posted on coil or distributer post about my problem and fix. My son took my 1980 F-150 with 300cid straight 6 to work. It sat all night and in the mourning would not start. Turned out to be the carb nuts were loose. Had gas in the oil and spark plugs were soaked and fouled. Changed oil and plugs tightened carb down and is running now.
Old Jan 1, 2011 | 07:45 PM
Wicked Endings's Avatar
Wicked Endings
Just because a few bolts were loose...
Sucks, doesn't it?
