Sponsored by: Real Truck
weird cubby hole
Old Feb 12, 2016 | 01:55 AM
mark_k's Avatar
mark_k
weird cubby hole
I have a little cubby hole on the drivers side of my 16 F350. Its on the lower part of the dash by where your knee would be? I pulled it out and it has 2 wires running to it. I was wondering what goes there in place of the filler compartment. I have googled pictures of 2015/2016 interiors and every one that has a clear picture of that area had the same thing. I cant imagine Ford would run wires just to plug them into the back of a plastic filler piece. If anyone knows what the option for that spot is, that would be awesome. Thanks
Old Feb 12, 2016 | 04:35 AM
Poncho450's Avatar
Poncho450
Possibly a spot for upfitter switches? Doesn't sound like a spot for a trailer brake controller.
Old Feb 12, 2016 | 04:48 AM
Larietpsd's Avatar
Larietpsd
Take a pic
Old Feb 12, 2016 | 04:58 AM
Just Strokin's Avatar
Just Strokin
Those wires are for the passenger airbag switch that you can install in place of the cubby hole. The crewcab does not come with the switch installed but can be purchased.
Part number for switch is BC3Z-14B268-A.
Old Feb 12, 2016 | 10:34 AM
mark_k's Avatar
mark_k
Ok, so nothing useful then. Was hoping if would be for adding a 110 outlet to the truck.
Old Feb 13, 2016 | 07:52 AM
Myyke's Avatar
Myyke
I found that i never used that pocket on my '14 F250, so when i got my '16 F250 I took the pocket out and used it for a 110v outlet when i put my inverter back in.
Old Feb 13, 2016 | 09:26 AM
Ferguson65's Avatar
Ferguson65
Just a useless pocket. Too shallow for anything. I mounted my pot for the high idle rpm control in it. Easy to get to but not easy to bump accidentally.
usmcdocj
Jun 24, 2017 11:13 PM
8e3k0
6.7L Power Stroke Diesel
Jun 23, 2015 03:46 AM
Rollin03F250
Electrical Systems/Wiring
Nov 20, 2009 03:09 PM
Fords and 1911
Mar 10, 2003 03:55 PM
