Sponsored by: Real Truck
Behind dash--access ?
Old Mar 9, 2003 | 08:50 AM
Fords and 1911's Avatar
Fords and 1911
I have decide to mount the switch for my addon lights in the hole fo the pedal adjustment switch.
My problem is I can't install the wires onto the switch with the switch installed without removing the dash panel.
I am hoping to tap into to ya'lls experience here.
What is involved in removing the necesary panel(s) to gain access for this install?
There appears to be three separate panels on the lower dash.
Do I have to remove them as a unit or do they separate once I get the right screws out?
Thanks!
Old Mar 9, 2003 | 09:42 PM
nafzimo's Avatar
nafzimo
There may not be much expertise out here. I don't think that the spot you are talking about even existed until '02. I know I had enough clearance to pop the plug out of the dash by removing the big panel under the steering wheel and reaching over. Do you have a switch that fits in the hole? Or are you going to drill a hole in the plug? The plug part number is 1C3Z-25044D82-AAB (tan).
Matt
Old Mar 10, 2003 | 06:32 AM
Fords and 1911
I got the plug out ok.
The switch I want to use fills the hole pretty well with a little dressing up.
I cannot attach the leads once the switch is installed, not enough room for my hand going through the side under the wheel.
This style switch won't allow me to attach the wires then instsall the switch either.
Maybe i I just need to look around and find another style switch.
Old Mar 10, 2003 | 06:43 AM
nafzimo's Avatar
nafzimo
I haven't found a switch that fits the hole, so I was going to drill the plug and install a toggle of some sort.
Matt
Old Mar 10, 2003 | 12:10 PM
Fords and 1911
Good ol Radio Shack sells an oval rocker switch that fits reasonably well. A very thin piece of black plastic, trimmed to fit between the switch and the dash looks really nice. IMHO!
Also with this style switch I had to use a backer plate on the back side of the dash for the nut to hold everything tight.
The number on the switch is R13-133. Since I really dont know I am assuming this is the part number.
I have used this exact switch on other application.
It has a bright red LED when in the on position.
I have found that if I mount it upside down the red light isn't awfully distracting.
I hadn't even thought of using a toggle. Will look into that.
Thanks
Old Mar 10, 2003 | 03:55 PM
Fords and 1911
The offending switch is now installed!
It really isn't all that bad to get to the back of the switch now that I did it.
Remove the radio
Remove the ash tray/cup holder (4 screws two up front two in the back)
Pop the instrument panel off
remove two screws from the top of the panel where the pedal adjuster switch/ plug is.
I was able simply pull the top of the panel out enough to make my connections.
Reassemble in the reverse order!
I also found the extra wires in the harness while I was under the dash.
Now all that is left is mounting the lights on the bumper and making the connections.
only1bigdaddyo
Apr 3, 2015 11:32 AM
paulhood
Mar 23, 2014 02:19 PM
johnday
2009 - 2014 F150
17
Feb 4, 2013 08:10 AM
Dazz
2004 - 2008 F150
May 7, 2005 07:55 PM
