1950 Ford Pickup
Old Feb 11, 2016 | 03:10 PM
Goosepop's Avatar
Goosepop
1950 Ford Pickup
I hope someone here can help me.
I had the metal frame for my vent windows chromed. I took out the old cracked hardened weather stripping and bought new to replace the old.
That's my problem...........how do I get the weatherstripping in the channel without marring the frame that I just had chromed? The weather strip is so thick that it would take great effort to force it in the channel and I've tried sliding it into place and that doesn't seem to work either.........
Is there a magical fix? Thanks in advance.
Old Feb 11, 2016 | 05:09 PM
raytasch's Avatar
raytasch
Believe Nothing
Welcome to the forum. Throw the weatherstripping away and use a sealer.
Old Feb 12, 2016 | 08:06 AM
1950FordF1's Avatar
1950FordF1
My 2 cents:
The tape I bought from one of the suppliers set the glass to loose.
A glass shop will have different thickness setting tape to get the correct fit. Sealer works but will be miserable to remove if you need to replace the glass.....
Old Feb 12, 2016 | 08:42 AM
JPMallory's Avatar
JPMallory
When I did mine, I had to use a small flat end screwdriver to compress the weatherstripping enough to get it into place. It took a lot of time and patience. If you keep a steady hand, you should be able to get it in without marring your chrome.
Old Feb 12, 2016 | 04:03 PM
saxtonj's Avatar
saxtonj
Perhaps try some silicone spray(or dish soap) to the rubber to make it slip into place easier and lessen the amount of pressure needed against your new chrome.
Old Feb 12, 2016 | 05:18 PM
1950FordF1's Avatar
1950FordF1
Glaziers generally use a medium soft rubber mallet to drive the frame onto the glass using a lubercant as suggested.
Old Feb 12, 2016 | 06:23 PM
CharlieLed's Avatar
CharlieLed
Take it to a local glass shop and have them do it...it will be cheap and done right. No shame in that.
SuperDuty93
18
Feb 22, 2013 01:27 AM
BigBlueCat
Jun 30, 2012 01:06 AM
bememe
Jul 13, 2008 10:43 PM
bememe
Jul 5, 2008 05:01 PM
learpilot
Apr 9, 2006 11:53 AM
