Vent Window Adhesive
Old Jun 28, 2012 | 06:04 PM
BigBlueCat's Avatar
BigBlueCat
Guys,
Can you recommend an adhesive to secure my vent windows into the metal channels on my 48 pickup?
Thanks in advance...
Old Jun 28, 2012 | 07:03 PM
52 Merc's Avatar
52 Merc
Vent windows do not use an adhesive. They're held together with a glass setting butyl tape, available at any local glass store.
Old Jun 28, 2012 | 08:05 PM
CharlieLed's Avatar
CharlieLed
That does bring up a good point though...seems like you could use any number of silicone adhesives to do the job. Might be a problem keeping the glass centered in the channel while the silicone set up though. Makes me wonder what Ford would have used if some of these hi-tech adhesives where available in 1948.
Old Jun 28, 2012 | 10:19 PM
52 Merc's Avatar
52 Merc
Instead of building their own like they did then, they'd outsource it to some small, specialty company to bond and encapsualte a frame and glass together for a fraction of the cost of hand crafting the part and for easy assembly. You also couldn't get it repaired at your local glass shop, but have to order a replacement from the dealer for $375.
If you put the glass and frame back together as it was intended, it makes replacement much easier and cleaner than having to clean up silicone or urethane before replacement. Keep it simple.
Old Jun 29, 2012 | 08:34 AM
BigBlueCat's Avatar
BigBlueCat
Any idea on the thickness to use?
Old Jun 29, 2012 | 10:18 AM
52 Merc's Avatar
52 Merc
I don't think there's too many options. I'd take both pieces to the glass shop and ask them for a strip of glass setting tape to put it together. They may even make you a good deal on doing it for you, so you don't have to worry about breaking the glass as you beat it into place.
Old Jun 29, 2012 | 10:52 AM
das54's Avatar
das54
Originally Posted by 52 Merc
Instead of building their own like they did then, they'd outsource it to some small, specialty company to bond and encapsualte a frame and glass together for a fraction of the cost of hand crafting the part and for easy assembly. You also couldn't get it repaired at your local glass shop, but have to order a replacement from the dealer for $375. . . .
When I was a boy my dad worked for a company that made vent window assemblies. IIRC their main business was stamping and chrome plating small parts. They made pretty much all the ash tray boxes for all 3. Anyway, my dad would bring home a small wad of the gooey rubber that they sued to set the window in the frame. He said they would heat it in a oven to set the rubber.
Old Jun 29, 2012 | 12:41 PM
mechmagcn's Avatar
mechmagcn
At my local "old school" glass shop, the owner showed me how to install the vent glass with seating tape. I was sceptical about his method, but it really works. Use motor oil to lube the seating tape, then press the glass into the channel. After a few hours the oil will absorb and you'll never know it was there. I have used this method many times and have never had a failure yet. And the good part is, you don't care have to use as much force and risk breaking the glass
Old Jun 30, 2012 | 01:06 AM
Jeeptrix's Avatar
Jeeptrix
Great advice that couldn't have come at a better time. I hope I'm not going too far off topic here but since we're installing new glass..
Has anyone opted for street legal smoked? For those in CA I'm still talking about glass!
4EyedTurd
May 1, 2019 03:04 PM
F&M
Nov 1, 2016 05:14 PM
Gotanoldtruck
Mar 19, 2014 05:22 PM
f100today
Dec 25, 2013 08:35 PM
3414
Apr 16, 2011 12:20 AM
