04 injectors same as 06?
Old Feb 11, 2016 | 02:31 PM
bobv60's Avatar
bobv60
I found some 04 injectors for a good price, will the work on my 06?
Old Feb 11, 2016 | 02:39 PM
WatsonR's Avatar
WatsonR
same same...
Old Feb 11, 2016 | 03:55 PM
cheezit's Avatar
cheezit
Does the part number start with 3c3z or 5c3z?
They will work however their is a reason they completely revised them.
Old Feb 11, 2016 | 06:56 PM
bobv60's Avatar
bobv60
They where advertised as only having 25,000 miles and pulled from a 04 last year. That doesn't add up, but the light surface rust on the bodies made it a no thank you. So now, I found a set out of a 2009 E450. Would those be the same?
The ones from the E450 where newly replaced and then fond out #8 cyl had no compression. So should have low/no miles and there is recepts
Old Feb 11, 2016 | 06:58 PM
cheezit's Avatar
cheezit
Yes they would be 5c3z 9e527 injectors.
Old Feb 11, 2016 | 07:17 PM
bobv60's Avatar
bobv60
Thanks all. The E450 are $100 ea and no core charge. I just need to find out who's rebuilt injectors they are. It sounds like the are Ford rebuilt.
Old Feb 11, 2016 | 09:13 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Just the core charge on those is $180, so that sounds like a really good bargain.
Old Feb 11, 2016 | 10:10 PM
bobv60's Avatar
bobv60
Just talked to the owner. He said the part # was 4C3Z, rebuilds from Ford. They where installed at the ford dealer and then when they started it they found the bad cyl. So no miles on them and where install last year. They are still in the van so they will need to be pulled out. I am happy that I don't have to mess with cores when buying on line (ficm repair is $202 for Ford rebuilds).
Old Feb 11, 2016 | 10:48 PM
73fan's Avatar
73fan
If you're planning to remove them from the van... I don't know how I want to say it other than it is very difficult.
Old Feb 11, 2016 | 11:13 PM
bobv60's Avatar
bobv60
It is being parted out so the cab will be off. Is there anything else I should get while I am there?
ptr34
Oct 6, 2008 04:01 PM
Sarge261
Feb 24, 2008 07:20 PM
beemr
Aug 5, 2006 06:23 PM
levi'sford
May 26, 2006 10:35 AM
nelgin
Apr 1, 2006 11:28 AM
