Batt Light
Old Feb 10, 2016 | 10:03 PM
silverbullet6oh's Avatar
silverbullet6oh
Batt Light
Hey guys. I have a question in this post.
After driving around I found that battery light was on, and then it eventually went to flickering and coming on and off. So after many moments of looking around the engine bay, I found the alternator positive terminal post was loose on the cable connection. Tightened it up and it went away.
But now when I go to start it sometimes the battery light comes on for a split second and then goes away after start up, not coming on again after start up
What gives?
Old Feb 10, 2016 | 10:12 PM
WatsonR's Avatar
WatsonR
what does Scan Gauge show?
Old Feb 10, 2016 | 10:19 PM
mhoefer's Avatar
mhoefer
Check all the battery connections and ground to frame, clean and dielectric grease too. Also, voltage cold soak, voltage cranking, voltage running after GPs off? Looking for condition of batteries and alternator function. Might need to load test both batteries and test alternator.
Old Feb 11, 2016 | 12:20 AM
silverbullet6oh
SG shows 11.2 lowest on cranking. 13.8 to 14.2 while running. I will check voltages in the morning.
It actually stopped doing the the three times I drove it since I posted this. Of course
Old Feb 11, 2016 | 07:20 AM
Jmoen7's Avatar
Jmoen7
Fords spec is somewhere in the low 9s cranking before it hurts the FICM. Not sure when the battery light comes on when running, but there is always a sensor to go bad. scangauge numbers are good
Old Feb 11, 2016 | 07:46 AM
WatsonR's Avatar
WatsonR
FICM spec is <9.5v. Battery light is 9.2v IIRC.
Clean all the grounds, frame, body, block.
Old Feb 11, 2016 | 07:48 AM
TooManyToys.'s Avatar
TooManyToys.
The terminal connection, was that for all connections to the batteries or just one of two or three?
My concern with an alternator intermittent connection is there was damage done to the control electronics within the alternator. Batteries would be fine, just possibly low in storage if the alternator is not charging at the full amps as it did new.
Old Feb 11, 2016 | 10:28 AM
silverbullet6oh
That connection that was loose was just for the one, at the alternator post.
I will be performing this task soon, just as a good measure.
The Batt light is only coming on now (sometimes) during the time I turn the key over, and then immediately goes away after started. Doesn't show up when driving now, since I tightened that loose connection.
One last thing, I was messing around with the fuel pressure testing port, and I drained the fuel a couple of times in the process. Then I did the procedure of "key on, engine off" to get the bowl filled back up. I did this full procedure twice. I know that this is hard on those batteries, as they are also giving juice to everything and the glowplugs.
So I will be putting the batteries on a charge, here soon. Maybe I drained them a little in that process.
Thanks for the help guys - Preston
Old Feb 11, 2016 | 11:20 AM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
I'd recommend pulling the alternator and having it bench tested just for the peace of mind at this point. As Jack rightfully indicated, having loose connections wrecks havoc on stuff.
Old Feb 11, 2016 | 11:53 AM
silverbullet6oh
Thank you Jack and Ed for the help. I will get that done.
Old Feb 11, 2016 | 01:41 PM
69cj's Avatar
69cj
To add to this, I've seen alternators bench test good when cold and bad when hot. Diodes can be self healing based on temp.
Old Feb 11, 2016 | 02:31 PM
TooManyToys.
Agree, I've seen that too. One of the ways it can happen is if the components are soldered with a poor junction, effected by shrinkage and expansion.
Old Feb 11, 2016 | 05:11 PM
silverbullet6oh
Uhhhh, what?
I am going to pull the alternator tonight, and have it bench tested tomorrow.
How do you bench test "hot"?
Or do you mean the alternator doesn't work correctly when hot.
Can someone school me please.
Old Feb 11, 2016 | 06:00 PM
TooManyToys.
It doesn't work correctly when it's at an elevated temperature. At normal room temp it's fine, under the hot hood it doesn't. Or the other way around too, just to make it more confusing.
Old Feb 11, 2016 | 06:18 PM
69cj's Avatar
69cj
Diodes used for rectification are one of the few electronic components that can be what's referred to as self healing. Can create major problems when trouble shooting.
