oil cooler o-ring replacement ?????
Old Feb 10, 2016 | 03:57 PM
Shattered's Avatar
Shattered
getting ready to start doing o-rings after a cold start and truck just pissed oil, so my question is, do I absolutely have to drain coolant out of radiator, or can I get away with draining block?
Old Feb 10, 2016 | 04:25 PM
Pikachu's Avatar
Pikachu
Draining the block will also drain most of the radiator. It'll just be a lot messier . . .
Old Feb 10, 2016 | 04:26 PM
Tugly's Avatar
Tugly
That depends on how much coolant you want in your oil pan. It's going in there no matter what you do, but you can limit the quantity. After the oil cooler job, I poured a quart of sacrificial oil in the engine with the drain open to push the coolant out.
Old Feb 10, 2016 | 04:34 PM
Shattered's Avatar
Shattered
That's what I thought, I already drained it. Thanks Tugley. Off to finish teeing this thing out. To bad it's not warmer out, it'd make this much more pleasurable.
Old Feb 10, 2016 | 04:51 PM
Tugly's Avatar
Tugly
Diesels malfunction in pleasant weather? Where? I'll pack my bags.
Old Feb 10, 2016 | 05:52 PM
Shattered's Avatar
Shattered
Northern Utah. when I pulled it free from the front mount and out of truck, the front o-ring wasn't on the cooler. I felt around up in the front cooler mount and didn't feel it there either.
Old Feb 10, 2016 | 07:27 PM
Pikachu's Avatar
Pikachu
It's in there. You should really pull the forward mount off so you can clean and inspect it anyhow.
Old Feb 10, 2016 | 07:31 PM
Shattered's Avatar
Shattered
Well this just keeps getting better in freezing weather. Lol.
Old Feb 10, 2016 | 09:42 PM
Firefighter 1406's Avatar
Firefighter 1406
I agree 100%. This went bad on my truck last year. In the winter also. It's not a bad job. Just remember when it's on the bench and you are cleaning it up the center section holds a LOT of oil. Took for ever for it to stop running out of there.
Arizona97
19
Jan 25, 2018 10:28 AM
Godzillamax
Nov 20, 2017 01:13 PM
stanley6.0
Jul 5, 2016 10:57 AM
Jesser02EX
Feb 3, 2014 09:34 AM
JWink
Sep 1, 2013 07:27 PM
