Sponsored by: Real Truck
2002 F250 Brake Problem
Old Feb 17, 2016 | 01:01 PM
  #31
davester250's Avatar
davester250
Originally Posted by Hogsters
I first bench bleed the MC and then installed bleeding just the MC lines after installing, then I was able to bleed all lines with the fluid squirting out properly... stops on a dime but I will keep an eye out. thanks again!
well, if you have a abs controller that needs to be separately bled, when it eventually gets activated, air will wind up in your lines...at a point in time when you really want the brakes to work as good as possible.
jniolon
29
Dec 15, 2017 11:59 AM
fordka
Jul 5, 2014 09:08 PM
robjs111
1997 - 2003 F150
Aug 14, 2010 08:11 PM
kmans777
Mar 20, 2008 07:53 AM
laplanten
Mar 17, 2008 09:48 PM
