BAMA tuner?
Old Feb 8, 2016 | 10:30 PM
79highboy150's Avatar
79highboy150
I understand what you mean on the firing orders of the injectors, but wouldn't they have had to use the harness to include the maf plug?
Old Feb 8, 2016 | 10:42 PM
Lead Head's Avatar
Lead Head
Who knows what they did. They could have hacked together various harnesses, they could have tried to correct the injector firing order issue by switching the connections around.
Old Feb 8, 2016 | 10:44 PM
DeathRangerofDeath's Avatar
DeathRangerofDeath
But first since this is a built engine, you need to verify which camshaft is in the engine. Thats what dictates firing order. If you put a 302HO firing order camshaft in, then you now have the HO firing order.
Old Feb 8, 2016 | 11:25 PM
79highboy150
its an e303 which matches the 5.0ho firing order
Old Feb 9, 2016 | 01:11 PM
DeathRangerofDeath
So you need to make sure both the injectors and the plug wires are in the HO firing order..one or both of those being wired wrong will definitely cause lack if power and other issues.
Old Feb 11, 2016 | 10:14 PM
79highboy150
i know the ignition firing order is right because I just did all new plugs n wires. In the process of tracing wires just haven't had the time with all the work I have going on
1994FordF-350MegaCab
Sep 10, 2018 09:57 AM
SmokeBlower
52
Feb 9, 2012 09:13 PM
Jrock909
May 28, 2007 08:45 AM
Dalamatition
180
Apr 11, 2006 08:05 AM
gabraham
Computer Chips & Tuners
Aug 1, 2003 12:48 AM
