Oil Pan Change
Old Feb 6, 2016 | 09:13 PM
deckertd's Avatar
deckertd
Oil Pan Change
I need some real data and no guessing here.
Has ANYONE installed a Milodon 7qt. (#31130) into a '71 F-250 CS/2wd/4spd/390/PS front sump truck? If so, did it fit or require some mods?
(FWIW, the 32224 windage tray WILL NOT WORK with a stroker engine.)
I know what the Milodon site states but I'm not convinced the pan will work. I pulled some rough measurements from my friends 69 390/auto wo/PS crawling through the mud but I'm just NOT SURE the Milodon pan will work.
Dan
Old Feb 7, 2016 | 04:36 AM
GaryKip's Avatar
GaryKip
Give them a call or email, with your engine specs. They'll help you out. Are you concerned about the fitting the front sump by the crossmember?
Old Feb 8, 2016 | 09:01 PM
deckertd's Avatar
deckertd
I'm concerned over the AMOUNT of clearance between the pan & the X-member. Is it 1/16", 1/2" or ???
Dan
Old Feb 9, 2016 | 03:03 AM
GaryKip's Avatar
GaryKip
Well they might be able to email you the spec sheet with the actual pan measurments.
Old Feb 9, 2016 | 08:11 AM
deckertd's Avatar
deckertd
Gary, I guess I'm not making myself clear. I already have the pan. What I'm trying to find is the amount of clearance between the Milodon pan and the X-member. I have no way to do a mockup to see what the clearance actually is. The vendor saying the pan will clear is of little use to me.
Dan
74scsp
Sep 17, 2013 10:06 PM
tim.beery
Feb 14, 2012 01:54 PM
supercabfreak
Jan 9, 2011 10:28 AM
Firemudder
Apr 21, 2007 07:58 PM
1QUICK75
Jan 10, 2002 11:56 PM
