Sponsored by: Real Truck
Spare Tire Key....
Old Feb 6, 2016 | 10:37 AM
Amish Ford's Avatar
Amish Ford
Spare Tire Key....
Awhile back, I ran across a thread about doing away with that stupid key, and using (I think) an ordinary 3/8 ratchet extention. Anyone know anything about it? I need to hang my spare, and want to modify the thing beforehand.
Old Feb 6, 2016 | 10:50 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
If you can get your tire down then all you have do is take the lift mechanism down and pry the female end of the key out, your crank will fit into the the slot in the winch.
If you don't have the key use a 14 mm extraction socket and a long 3/8 extension to lower the winch and then remove the key in the winch.
Denny
Old Feb 8, 2016 | 04:24 PM
ufvj217's Avatar
ufvj217
yea i forgot the size sockets, i think what mentioned above is right, but i used the socket method with long extensions and it worked after a few attempts. i read you can take the lock adapter thing off and then not have to worry about it, but i haven't tried to take mine off yet. i still have the spare tire in my bed, so i haven't messed with putting it back in the stock location yet.
Old Feb 8, 2016 | 07:04 PM
fordman19762003's Avatar
fordman19762003
I just popped the special end off the winch and threw it away. If someone really wants to steal your spare tire that special end isn't going to stop them for long.
Pushdeck1
May 23, 2024 08:47 PM
indebt
13
Feb 18, 2009 02:40 PM
shovelrocker
Jun 27, 2007 03:13 PM
Trouble1263
Aug 1, 2006 10:52 AM
glantineman
1997 - 2003 F150
Feb 8, 2004 09:18 PM
