E4OD to ZF5 questions
I believe my auto is beginning to go out after 235k miles and i am wanting to put a zf5 in it.
questions are what all do i exactly need? it is a 1991 f250 2wd w/o a turbo.
i am also wondering if anyone has done a zf5 to erode swap that may have parts i could get from.
how hard is the switch?
i don't want to have a shop bend me over and i am pretty mechanically inclined but this would be my biggest project yet. i would have help.
all help and tips appreciated..thank you all.
Some of the quirks of putting a ZF into a 80-86 body style do not apply in your case, but read my long post #5 in this thread:
https://www.ford-trucks.com/forums/1...a-6-9-idi.html
Edit: since you are 2wd you may need a different drive shaft. I don't know if those transmissions are equal length like C6 and ZF 4x4 models.
The big ones are Clutch/flywheel, Mounts/Members, Wiring/Computers, (because you had an e4od) driveshaft, and Pedals. and oh also good luck finding a cheap 2 wheel drive zf5. but yeah, its exactly what i did on my truck, but the opposite because the previous owner on mine drove like a turd.
Received 3,110 Likes
on
More questions for y'all..
Will the bell housing be the same or will I have to mess with it?
The pedals.. Do they have to come off of another diesel or can they come off of an 87-91 gasser? (F150,250,350??)
Also I was reading up about the brake and reverse lights will need some rigging??
Thank y'all so much
Thank y'all so much
on
on
Another option, although more expensive is to get a 4x4 trans and
transfer case. This would give you low range if you ever do any
really heavy low speed stuff. For example, I have a 14k lb traier I tow
sometimes. Backing up a hill loaded down its nice to have low range.
Even unloaded its nice because idling in reverse is too fast in tight
quarters.
quarters.
on
on
