Cold weather Prep?
Old Feb 5, 2016 | 10:05 PM
Macrobb's Avatar
Macrobb
Honestly, unless the temps get down to below 20F, don't worry about anything.
If you expect temps in the 10F or lower range, then you should prepare a little(this is when you want the diesel additive). 30F isn't anything to worry about at all.
A good glow plug system on an IDI will start it down at 10F as long as the fuel isn't jelled.
Old Feb 5, 2016 | 10:47 PM
Skip1970's Avatar
Skip1970
can always light a candle or a 1/2 soda can with diesel in it and set under oil pan that helps too if your really desperate
Old Feb 6, 2016 | 12:46 PM
Mizuez's Avatar
Mizuez
I do agree after reading a lot of the responses and doing some research on the weather now that the date is closer. I've never had experience with a diesel in snow before so I wantedto make sure all my bases were cover even if unnecessary.
Old Feb 12, 2016 | 01:03 PM
Mizuez's Avatar
Mizuez
I finally got out to test my Block heater. I used a ohm Meter on the cord coming out the front and didn't like the results. My meter read OL. I didn't have much time to look into it any farther but at this point I know I can't use the block heater.
I either have a bad cord going to it which I don't drought. The cord looks original from 1989 and most likely never used or touched. I don't even think the previous owner knew it was there.
Or I have a bad element. More test is required to see if that's the case
I guess its good news to find out I wont need it unless we encounter sub 0 temps.
Old Feb 12, 2016 | 03:20 PM
bashby's Avatar
bashby
Check to make sure the cord is stii plugged into the heater.
Old Feb 12, 2016 | 03:48 PM
Mizuez's Avatar
Mizuez
Ah yes. I did not check that. I was testing it late last night. Hopefully in the morning I'll be able to check into it farther. Maybe even get the cord out and test it separately to make sure is got good connectivity through out.
Old Feb 12, 2016 | 06:04 PM
82F100SWB's Avatar
82F100SWB
Quite often the wires will break just behind the plug and all you need is a new end.
Old Feb 17, 2016 | 05:13 PM
Mizuez's Avatar
Mizuez
Talking Thank you
Good news everyone. The trip was a success. The truck preformed beautifully and had no issues what so every. Actually it even got double the range out of the fuel than I normally get which was a nice bonus.
Thank you all for the help making it a hazard free trip.
Old Feb 17, 2016 | 05:52 PM
Skip1970's Avatar
Skip1970
I knew you'd be fine. Congrats on your first cold weather trip in a idi.
Ford Trucks
Official Ford Forum : Ask an Engineer
Aug 21, 2016 10:08 PM
chemoman
6.4L Power Stroke Diesel
Nov 2, 2012 12:01 PM
FordFanFrits
Dec 3, 2009 09:46 PM
just another truck
29
Jan 16, 2009 03:24 PM
celjel
Nov 6, 2005 07:37 PM
