Coolant leak
Old 02-04-2016, 02:09 PM
Derek Finkle's Avatar
Derek Finkle
Derek Finkle is offline
Coolant leak
93 f150 4x4 5.0
My truck started overheating the other day. I replaced the thermostat and topped off the coolant and when the radiator was nearly full, I noticed cool pant pouring out of what seemed to be, the oil pan gasket. Could this be a head gasket issue? I checked the oil on the dipstick and its normal. I need some advice
Old 02-04-2016, 02:11 PM
Derek Finkle
The coolant that leaked from above was from a crack in a hose. I repaired that.
Old 02-04-2016, 02:22 PM
chrismd188's Avatar
chrismd188
chrismd188 is offline
if the oil pan was pouring coolant out you'd see it on the dip stick. My guess would be the thermostat housing didn't get seated all the way. Did you put the thermostat in the housing then the gasket on top. I use a little bit of rtv silicone on both sides of the gasket just to hold everything in place since there thermostats in kind of a tight place on the 5.0's
Old 02-04-2016, 02:26 PM
Derek Finkle
Yeah, installed a new thermostat housing gasket and it sealed nicely. No leaks from that
Old 02-04-2016, 09:07 PM
Derek Finkle
I've read that it could be coming from ta freeze plug. Where are they located in the 302?
Old 02-04-2016, 09:18 PM
88n94's Avatar
88n94
88n94 is offline
The freeze plugs on any V8 are on each side of the engine block a ways below the exhaust manifold. They are round, about 1 and 1/8 inches in diameter.
Old 02-04-2016, 11:18 PM
justcruzin125's Avatar
justcruzin125
justcruzin125 is offline
Check at the seam where the timing cover and the block meet. Thats where mine is leaking from and drips down to the rim of the oil pan
Old 02-05-2016, 01:12 AM
Derek Finkle
Ok. That seems a bit more probable. I'll check it out tomorrow.
Old 02-12-2016, 09:19 PM
vochy's Avatar
vochy
vochy is offline
You can replace some of the freeze plugs with the motor still in the truck. I thought i had one leaking but it ended up being a broken head bolt that was leaking coolant out between the head and the block. It is tricky to figure where coolant is leaking from, there are a lot of places it leaks down from.
Old 02-13-2016, 01:45 PM
Derek Finkle
Thanks fellas. It turned out that it was the seal on the water pump that apparently goes bad when the pump starts to fail
Dank Hill
02-23-2016 09:20 AM
D.Schantz1
05-10-2015 02:13 PM
KrenzyRyan
01-03-2008 01:04 PM
Andywk
10-14-2005 11:39 PM
jdawg11386
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
06-11-2004 11:15 AM
Quick Reply: Coolant leak
