coolant leak
Old Mar 15, 2004 | 08:51 AM
jdawg11386's Avatar
jdawg11386
Question coolant leak
My explorer is leaking coolant and i'm wondering how hard it will be to fix this myself. If you look at the engine from the front of the car (V-6 SOHC), there is a black thing with a coolant hose coming off it in the front under the plastic shield but just above the serpintine belt. coolant is leaking out of the side of it. is this a gasket that I can replace??? if so, what is it called? thanks for any help!!!
Old Jun 11, 2004 | 11:15 AM
dangerRanger91's Avatar
dangerRanger91
yea are you referring to the thermostat housing?? if so yes this is gonna be cake to replace just a small gasket for the thermostat and possibly a new thermostat housing
