Brake Issue
Old 02-04-2016, 09:29 AM
renchr56's Avatar
renchr56
renchr56 is offline
Brake Issue
Good morning all... I have a 2008 Ranger Sport 4x4. I noticed yesterday that when I stepped on the brake pedal it felt like nothing was there until I step a little harder then it was like full brake application. The truck only has 63000 on it. Then every once in awhile it would be normal ie very light brake application and slows like it should. Then back to same issue... Any thoughts about this??
Old 02-04-2016, 11:46 AM
Josh S's Avatar
Josh S
Josh S is offline
The system is just hydraulics so if it's taking extra foot pressure to engage the brake pads you've got something hanging up somewhere. A stuck caliper piston is a good possibility and if the truck pulls to one side when braking that's usually a dead giveaway. If the steering is not pulling it could be something further upstream like the master cylinder hanging up or fluid gummed up in the line. Has the fluid ever been changed? Hope you get it solved.
Old 02-04-2016, 12:21 PM
renchr56's Avatar
renchr56
renchr56 is offline
Yes I've changed the fluid not too long ago and all was fine. There is no pulling issues either.
Old 02-04-2016, 01:46 PM
spooktn's Avatar
spooktn
spooktn is offline
Does it have a break booster,, and if it does to you hear a low noise like air leaking when you depress the peddle ??????
Old 02-04-2016, 02:09 PM
renchr56's Avatar
renchr56
renchr56 is offline
Yes it has a booster and no leakage anywhere
Old 02-05-2016, 07:57 PM
DanielF250Hauler's Avatar
DanielF250Hauler
DanielF250Hauler is offline
Bleed the brakes the old fashioned-way...
look for leakage around the cylinders by squeezing the rubber boots...
Old 02-06-2016, 06:52 AM
renchr56's Avatar
renchr56
renchr56 is offline
if there was leakage the fluid level would change in the master cylinder. It is still same level. some days it works perfectly fine. Then at times it isn't
Old 02-06-2016, 10:25 AM
78 PEB's Avatar
78 PEB
78 PEB is offline
Possible that the vacuum line from the manifold to the booster is loose?
Old 02-06-2016, 11:37 AM
reddog99's Avatar
reddog99
reddog99 is online now
I have nothing specific to add, but your description sounds like a master cylinder problem. If it was a wheel cylinder problem it would either brake very unevenly or lock up one wheel, not affect the whole system behavior. Maybe your flushing of the brake fluid knocked loose a corrosion particle? Did you flush enough to get the old fluid out of the ABS unit?
joegeds
03-10-2016 04:52 AM
mjpmn
1997-2006 Expedition & Navigator
03-06-2011 02:06 PM
Tech-savvy
01-05-2009 10:27 AM
Shadowe
01-14-2005 06:10 PM
lodge308
09-01-2004 08:59 PM
Quick Reply: Brake Issue
