Broken radiator drainplug
Old Aug 9, 2003 | 10:39 PM
Jethro28's Avatar
Jethro28
Angry Broken radiator drainplug
I screwed up and broke off my drainplug on my 99 explorer when I was changing the coolant. It is pluging everything up and appears to be stuck. Can you buy another drainplug? I did do the coolant change but what should I do ablout the plug? Please help. Will the plug unscrew all the way out, if I could get it to do that??
Old Aug 22, 2003 | 08:42 PM
Michael013's Avatar
Michael013
I have a 98 Explorer XLS SOHC 4.0 and the drain plug comes out all the way. i attach a icemaker tube to drain outlet open valve, then use a pump to suck it out quicker. Sometimes I just slowly remove the lower radiator hose and drain it into a pan.
Moonpie6899
May 22, 2016 10:59 PM
someday
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 15, 2013 03:04 AM
hubler13f
Mar 27, 2010 07:15 PM
jtharvey
77
Oct 3, 2007 08:18 PM
01' Super Crew
1997 - 2003 F150
Mar 6, 2003 09:26 PM
