screwed up my coolant flush, what would you do?
Well, my truck hit 72,000 miles and I figured along with the oil change I would also do a coolant flush and install a coolant filter. So I went out and bought the VC9 and the Premium Gold coolant.
I started out the flush right by draining the coolant from the block and the radiator and removing the thermostat. I then put 2 Quarts of VC9 in and filled it with distilled water, ran it for about 40 miles and heres where I screwed up. I then drained the VC9 and water from the radiator (It was the color of MUD) and forgot to open the block drain plugs. I filled it up with water again ran it for a while and drained the radiator again forgetting the block drain plugs. I then installed my dieselsite coolant filter and thermostat and realized my mistake when I put 3.5 gallons of coolant and .5 gallons of water and it was full. I'm positive that I am below 60% coolant and it's testing good. But I have no clue how VC9 works or what the effects of what may be left in there may have. Just looking for some opinions. would you flip the $80 for coolant and do it again, or call it good. I'd hate to waste all of the stuff I already put in just to reflush it but if it could have adverse effects down the road I don't want to risk it.
I could be wrong and some of the pros here will let me know if I am but if you flushed it twice you should have most if not all of the VC9 removed. And if you added 3.5 gallons of anti freeze then you are slightly over 50% antifreeze and should be good to go. I was told that the ford techs at the dealership i use, only use 3 gallons of antifreeze doing a cooling flush.
Thats what I was thinking. If my math is correct then I would have less than 1/2 a quart of vc9 still floating around in there. It is pretty aggressive stuff though. I couldn't believe the color of the crap that came out of that first flush, there was no transparency at all. Just dark brown muddy water. I went a little high on the coolant with the thought of the increased capacity due to the coolant filter and losing some coolant on the first filter change in a couple of months.
I'm not sure whether the long term effects of having VC9 running thru the system for any extended period of time will hurt anything or not...you're going to change your first coolant filter after 500 miles anyway....right? Sure you are. Next time though...just drop the lower rad hose and you should have dumped enough...also, use Valvoline's Zerex G-05 same spec...I'ts my understanding that Valvoline makes Motorcrafts coolant. Zerex is only $11 gallon.
Will do!
One last question.....does it make more sense to install the coolant filter after the first drain, or wait until after the multiple flushes of distilled water? Seems to me that I might want it in right away to catch any of the sand that get dislodged and moved around during the flushes. Whataya think?
Will do!
I would definately recommend using the VC9 especially after seeing the crap that it washed out of my coolant system. It is quite pricey, I spent $56 for 2 quarts of it but after seeing the crap that it knocked out of my engine I would definatly recommend it. Also add a coolant filter when you can. Dieselsites filter is a great setup and it looks good when you pop the hood.
