429 history?
Old Feb 3, 2016 | 08:14 PM
J ballan's Avatar
J ballan
429 history?
Hello everyone I picked up a parts truck recently that came with a 429. The heads read D0VE-C not sure about the block. I'm sure it came from a car because the frame was notched to clear the car manifolds and it has a huge front sump oil pan. I've read that some of these early 429s had pretty high compression and I'm not sure if I can run it on regular 87 octane pump gas? If not it's not much good to me as I don't want to be buying 90+ octane fuel. Thanks for your help.
Old Feb 3, 2016 | 10:10 PM
wtroger's Avatar
wtroger
D0ve-c head are the most desirable of the stock 385 heads on a flattop piston 429 they will make 10.5 -1 compression. So pump gas might be an issue.
Old Feb 3, 2016 | 10:29 PM
85e150's Avatar
85e150
Some of those were 11.3 as OEM. 87...not.
Old Feb 3, 2016 | 10:42 PM
wtroger's Avatar
wtroger
The key word is flat top Pistons. CJ engines didn't have flat top Pistons
Old Feb 4, 2016 | 07:38 AM
J ballan's Avatar
J ballan
I'm pretty sure it's not a CJ but I will check the block casting numbers tonight. So that means it has 10.5-1 compression correct?
Old Feb 9, 2016 | 04:36 PM
smallello's Avatar
smallello
Are we there yet?
I have a 429 from a 1970 LTD. It has D0VE-C heads also. I run it on regular pump gas with no issues.
Old Feb 9, 2016 | 05:31 PM
J ballan's Avatar
J ballan
Thanks for the reply. I've got a good TMyer 400 I'm going to use instead. I'll save the 429 for my mud truck.
FORDMANMATT
Nov 8, 2013 06:50 PM
gus11208
Aug 8, 2010 09:06 AM
northern 7.3
Oct 2, 2008 08:24 PM
jj292
Sep 27, 2003 12:09 PM
erikl85
Apr 16, 2003 08:36 AM
