469 compression ratio
Old Aug 8, 2010 | 08:46 AM
gus11208's Avatar
gus11208
I have a 72 460 and i have just learned that the D2ve heads are the worse thing since hitler. I have a set of dove heads to put on . my problem is i have my block decked the pistons are only 5 thousenth in the hole and they are flat top pistons does any know what my compression would be and will have any valve clearance issues I still would like to run 93 octane but i think ill be pushing my luck. i am thinking any thing from 10.5 to 1 to 11.5 to 1 is this the case?
Old Aug 8, 2010 | 09:06 AM
JBradley500's Avatar
JBradley500
75.8cc chamber, 0cc piston, .005" in the hole with 4.440 head gasket is like 11.48:1
thats pretty dang high for pump gas in a truck with a small cam.
