Bronco II Ford Bronco II
No Brakes !!
Old Aug 9, 2003 | 10:07 PM
bobbyjoyner's Avatar
bobbyjoyner
No Brakes !!
Hi everyone -
I have a little brake issue that you may be able to assist me with -
I have a 89 4x4 Bronco II that just loss about 90 % of its brake pressure at the pedal. I have no visible leaks along any line, and I am not losing fluid. Despite this, my pedal pressure is almost zero. At first, I assumed that the master cylinder was the culprit, allowing bypass when pedal is applied. While inspecting the M. cylinder, I pulled the vac. hose that runs from the intake to the brake booster body... instant pedal resistance resulted. In fact, I could not even move the pedal against the resistance. Over the course of the 3 years I have owned the truck, the rear antilock light has intermittently illuminated. The light currently comes on 1-2 seconds after starting the truck, and stays on....
Any ideas what the problem may be?
Thanks, Bobby
Old Aug 11, 2003 | 10:48 AM
Ken00's Avatar
Ken00
No Brakes !!
Welcome to FTE!!!
I still think MC. See the tech info post on RABS testing.
Old Aug 11, 2003 | 02:10 PM
bobbyjoyner
No Brakes !!
Ken -
Thanks for the info... I printed the RABS testing info from the tech link. I will give it a try and see what is happening....
I really hope it is just the MC, looks like that would be about a 2 hr / $50 driveway project... I will post my results after I run the diagnostic...
Bobby
Old Aug 11, 2003 | 09:06 PM
native's Avatar
native
Post No Brakes !!
I also have a 89 Bronco II I lost my pedal and had to replace
my brake booster that was the problem. I also had to replace
every other brake part. Now I have a exhaust problem.
I hope this helps!
oldguard60
16
Jun 11, 2014 04:39 PM
cooploops
Oct 25, 2007 06:35 AM
dkrolak
1983 - 2012 Ranger & B-Series
Mar 21, 2006 03:21 PM
joe_mule
Mar 31, 2004 02:15 PM
gbaumgar
Jan 14, 2004 08:23 AM
