I have a 1994 Ranger SuperCab 4.0 V6 manual transmission. I went to start my truck and the brake pedal went to the floor with little resistance. I started the truck and the brakes do not work. I have to apply the parking brake to stop the vehicle. I checked all lines and found to visible fluid leaks. I bled the master cylinder and brakes per my Haynes Repair manual. However, when I attempted to bleed the rear brakes no fluid was released during the process. When finished still no brakes and pedal goes to the floor. Also when I depress the brake pedal the fuild in the master cylinder resevoir bubbles. I want to repair the vehicle myself to save $. Any suggestion are greatly appreciated.
Sounds like the master cylinder has gone bad and is bypassing fluid internally. Master cylinders aren't too bad to do. Mostly a lot of bleeding to get all the air out of all the lines. A new one can also tell you if some of your brakes are not working correctly too, like rear wheel cylinders that won't work well when you push on the pedal.
I agree, sounds like the brake master cylinder has gone belly up.
The reman master cylinder I used in my old Zypher had a "bench bleed kit" with it, so I could put fluid in it & pump the air out as it recycled the fluid back into the reservoir, as you pushed the piston. This "bench bleed" routine you do before you reconnect the brake lines to the master cyinder.
It'll save a lot of time bleeding the brake system & you sure don't want to get air into the ABS motor, cause you'll likely end up at the Dealer to have the system vacuum pumped, to get it all out!!!!
Thanks for the advice. I swapped out the master cylinder and bled the system and the brakes worked when I road tested the vehicle. The action on the brake pedal is firm and has little travel. However, I am not quite sure everything is ok because when I bled the rear wheels I did not get any fluid. The front brakes bled well. Why no fluid from the rears?. . I am worried that only the front brakes are working? Do I pull the rear wheels to see if the rears are working?
This forum is a great resource. Thanks for the help.
Well you could raise the rear wheels & see if you can stop the wheels rotation with the brakes.
Not getting fluid from the wheel cylinders isn't normal, but may be because they're bleed hole is rusted up.
Did the bleed fittings have the rubber cover caps to keep water & debris out???? If not, open the bleed fitting & try using a small piece of wire to oen it up so the wheel cylinders can be completely purged with new fluid.
Be sure to use a box end wrench on the fitting & pump enough fluid out to completely recharge the wheel cylinders with new fluid.
Keep a check on the mastercylinders fluid level & keep it topped off. Don't let it get so low as to suck air in while bleeding the wheel cylinders.
Thanks for the earlier advice. The brake master cylinder had gone bad. I swapped out the master cylinder and bled the system and the brakes worked when I road tested the vehicle. The action on the brake pedal is firm and has little travel. However, I am not quite sure everything is ok because when I bled the rear wheels I did not get any fluid. The front brakes bled well. Why no fluid from the rears?. . I am worried that only the front brakes are working? Do I pull the rear wheels to see if the rears are working? Should'nt the rear brakes expel fluid when bled?
Vehicle: 94 Ranger 2wd v6 4.0 L Rear Anti Lock Brakes
Just jack the rear end off the ground, and spin the tire, while someone else applies the brake. That should tell you if you're getting any rear braking. If you take the drum off, and hit the brake, well, you'll run into problems with the brake cylinder overextending and you'll have brake fluid all over the place. Not to mention you will have to replace your brake cylinders.
What I do is a gravity bleed until fluid starts to come out, then do a pressure bleed. That works for me 99% of the time.
Edit: Just have to make sure you got the correct master cylinder? And the fluid was topped up in both reservoirs? And when you bled the brakes, you did the rears first?
I didn't check to see your previous problems, so I want to make sure you got your bases covered.
Something else, just as a side note, and I'm sure you already know this, but a bleeder doesn't just crack to bleed, you may have to turn it a bit more to get anything.
Or maybe check for a kink in the line going to the rear brakes.
I loosened the supply line that goes in the rear wheel and pumped the brakes. Still no fluid. Could the problem be at the RABS porportional valve. When I bled it , per my Haynes manual, I also got no fluid. I''ll check for kinks in the line.
