I'm a new member
Old Feb 3, 2016 | 08:41 AM
66EFFY's Avatar
66EFFY
Unhappy I'm a new member
I have a 1966 F100 custom cab style side truck. I've been having problems with the electrical system. The truck will start up fine and idle somewhat smooth. When I rev the engine up to about 2500 RPM it starts backfiring thru the exhaust and running real rough. The new items that I have installed are edelbrock carb., one wire alternator, and a HEI distributor. I've checked the timing, checked plugs, checked for any loose wires and I'm drawing a blank. Any advise will be great. Thanks
Old Feb 3, 2016 | 08:53 AM
Tedster9's Avatar
Tedster9
Welcome to FTE
Did it run OK before you replaced those parts?
Old Feb 3, 2016 | 09:02 AM
66EFFY's Avatar
66EFFY
I'm a new member
It ran O.K. before I added those new parts. After I installed the new parts it ran like a champ. I did one simple little burnout and it started to run like crap after.
Old Feb 3, 2016 | 09:04 AM
Skip1970's Avatar
Skip1970
welcome to FTE!
sit back and enjoy a musical video.
Old Feb 3, 2016 | 10:03 AM
66EFFY's Avatar
66EFFY
Technotronic... Turn them ****s up!!!
Old Feb 3, 2016 | 11:31 AM
Tedster9's Avatar
Tedster9
Start with the basics. Bring #1 piston TDC compression, observe where distributor rotor points. Should be just shy of the #1 spark plug wire terminal location. With wrench on balancer bolt turn crankshaft back and forth, note how much slop before rotor starts to turn. It may be the timing chain is loose, and the engine skipped timing? Just a WAG.
Old Feb 3, 2016 | 01:18 PM
66EFFY's Avatar
66EFFY
Thanks Tedster9 I will try that as soon as I get home from work today. I will let you know how things went tomorrow.
Old Feb 3, 2016 | 01:25 PM
Tedster9's Avatar
Tedster9
Yep, "backfire" through carb or exhaust is basically a timing problem. A vacuum gauge connected to manifold vacuum source would be useful, if it turns out that the valve/timing chain is OK.
Ted
thecause17
31
Mar 27, 2022 01:39 PM
84espy
Feb 1, 2019 11:02 AM
tseekins
19
Aug 16, 2014 04:38 PM
cigarxtc
Sep 5, 2013 07:06 AM
