Water in DEF tank ???????
It has to be measured at the exhaust because if you play games with diluted DEF (or remember the recent thread about using ammonia in lieu of DEF?) the system simply dumps more fluid in to accomplish the cleansing reaction. I can't say I've tried it or would try it to answer the question for anyone. That was one of the all-time fail threads.
I'm curious how the truck "knows" the DEF is contaminated? I think the only way it concludes this is based upon the reporting of the NOx sensor. Basically the tank contains a heating circuit, the pump, and the 4 electrodes for measuring DEF level. The tank heater, pump heater, and line heaters are all controlled by two power circuits (MOSFETS, I think) in the glow plug module. They only heat based upon ambient temp. The pump cannot detect what it is pumping, and I don't believe the electrodes can do anything other than detect level by conductivity. That leaves only the dosing injector and the NOx sensor. The injector verifies its own operation and can report a fault code if it is not working properly...as can the NOx sensor. Therefore, if the PCM notes that their is DEF in the tank, the DEF injector is working, and the NOx is also working, but the NOx reading is not within acceptable range, the system concludes that the DEF is contaminated. DEF can get old and not perform as intended, or something other than DEF could be added (like water). The NOx is foolproof - the EPA wins if there is too much NOx coming out the tailpipe; the truck derates or shuts down.
This was from a thread started by Justin "Iron Cobra".
smokem331
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
16
04-09-2013 09:57 AM
Milwaukee1979F150
03-17-2008 04:16 PM
maevans
05-03-2007 04:24 PM
