Sponsored by: Real Truck
Headlight help please
Old Feb 1, 2016 | 06:00 PM
motomech10's Avatar
motomech10
2008 F250 Super Duty 5.4L
The left drivers side high beam aims at the ground about 10 feet in front of driver, low beam seems fine and properly adjusted. As I turn the adjuster to raise the high beam it appears to throw the low beam out, making it aim to high. Right passenger side hi-low appears to be adjusted properly. Truck is new to us last month, and this became an issue after I removed the plow.
I am also looking for the service/shop/repair manual, prefer OE same vehicle
Pictured with plow but I am referring to when plow is not attached
Couldn't find much info or video on this model.
Thank You
Old Feb 1, 2016 | 06:08 PM
moymurfs's Avatar
moymurfs
Make sure the bulb is seated properly in the reflector and wasn't bounced when you were plowing. If it is seated, look at the filaments inside. There's a chance one got knocked askew. Lastly, try another bulb.
Old Feb 1, 2016 | 06:10 PM
motomech10's Avatar
motomech10
yup good suggestion I'll check it tomorrow. Thank You!
Old Feb 3, 2016 | 12:27 PM
motomech10's Avatar
motomech10
Someone had put the bulb in upside down easy fix thanks
2010f3504x4
Feb 8, 2019 01:56 PM
Bleishear
Electrical Systems/Wiring
Oct 26, 2018 07:03 PM
highteckredneck
1997 - 2003 F150
May 19, 2010 01:55 PM
is300wrx
2004 - 2008 F150
19
Jul 24, 2006 12:48 AM
PA F150 4X4
Jun 2, 2003 07:01 PM
