Locating EEC Relay
Old Aug 9, 2003 | 07:43 PM
VNAMUS's Avatar
VNAMUS
Question Locating EEC Relay
I have a 91 Ford Explorer 4.0 liter. It is blowing the 30 amp EEC RELAY in the power distribution box. If I put a new one in, it blows a few seconds after turning the key to the ON position. Please help me to diagnos this problem. I was going to replace the EEC relay...but I can't find it. In the book it give the code E97B-14A0984-AA.
Old Aug 9, 2003 | 08:13 PM
HomerWinzlow's Avatar
HomerWinzlow
Locating EEC Relay
The EEC Relay and Fuel pump relay are located UNDER the power distribution box you are swapping out fuses in. They are clipped to a panel that is placed directly underneath the PDB. I had one doing this exact same thing the other day. I found the wiring loom on the driver side resting on the exhaust manifold and shorting out because it had burned through. After repairing the burned/shorted harness and rerouting I found the fuse still blowing. After further diagnostic and short tracing I found the transmission shift solenoids in the tranny were shorted, likely due to the original shorting at the manifold on the loom. I sent it to the transmission shop for replacement of the solenoids in the transmission.
ratsram
1983 - 2012 Ranger & B-Series
Jun 28, 2012 01:02 PM
troposcatter
Electrical Systems/Wiring
Dec 11, 2002 10:34 PM
fatforty
Jan 21, 2001 11:24 PM
