flexomatic spring busings
Old Feb 12, 2016 | 06:20 PM
  #31
orich's Avatar
orich
Originally Posted by JEFFFAFA
Exactly. All the poly bushings I've installed have used the original outer sleeve. Ya might consider keeping them greased with either a zerk fitting or some of that sticky silicone grease the bushings come with. Seems to me the inner surface of the spring eyes are as rough textured as the outer surface. Unless you smoothed out the inner surface with something like a reamer.
My spring eyes were all nice an smooth as my truck is a California native with out any harsh winters in San Jose and was a Ca. desert for about 12 yrs.
I put in the OEM ones in 1978 the yr ,I got the truck and with the camper on for so long needed to replace rear springs, got a pair from a f350 and put poly bushing into them about 15 yrs ago. Then replaced the fronts about 5 yrs ago from a 75 4wd f250 and those spring eyes were smooth also. Just remove rusty dirt with an wire wheel. Then lubed everything and use a rubber mallet whacked them in then the center bushing did the same.
Now if if I was on the east coast mid west then would need may be a reamer or grinding wheel to smooth then up so..
But what would a guy do if his inner sleeves were all bad and could not put in the polys bushing. Just forget about using them and order oem ones.
Orich .
  #32
Randle's Avatar
Randle
Originally Posted by orich
Jeff I've always had to remove the inner steel shell sleeves to install poly bushings. A perfect fit in the spring eye hole for the one's I've installed front & rear on all my 4wd spring eyes.
May be on others vehicles that you've have done used the steel sleeve.
Orich
Both of you are right, some brands use the outer bushing, but Energy Suspension tells you to remove them.
Old Feb 13, 2016 | 10:02 PM
  #33
idealtrucks's Avatar
idealtrucks
So I worked on then today, hacksaw and a chisel removed the inner sleeve no problem. Took a grinder and cleaned up the inner real good, put some oil in there and tried installing new bushing by using piece of all thread and some washers. I have got them squeezed in till they lack about an inch but can't get them further. It was around 10 degrees here today, so I'm hoping that's the problem.
Old Feb 13, 2016 | 11:54 PM
  #34
orich's Avatar
orich
I know there a real Bi~ch when, I first did mine in 78 this was why I went with the poly bushings. Pound in each haft then drive in the center done sleeve.
If you have a big HD vise or a have a shop press them in.
Use may sure you oil the all thread threads helps.
I finished beating them in with a BFH
But poly bushing do make the ride a little harder.
Orich
Old Feb 14, 2016 | 04:20 AM
  #35
JEFFFAFA's Avatar
JEFFFAFA
Ah. Take them back out and stick those bushings in the freezer for a while. Shrink 'em. Then use something thinner like spray liquid graphite. Which BTW works great at lubing house squeaky house door hinge pins. Take a punch and hammer and pop out the pins one at a time from bottom to top. Lube with it and replace. The wifey may...........
Old Feb 14, 2016 | 10:25 AM
  #36
MIKES 68 F100's Avatar
MIKES 68 F100
for cold weather drop the bushings in a bucket of almost boiling water, let sit for 15 minutes or so
Old Feb 14, 2016 | 10:47 AM
  #37
GLR's Avatar
GLR
Won't that expand the steel making harder to press in place?
Now if you put the spring end in hot water....
As above, freezing the bushings would be better.
Old Feb 14, 2016 | 11:21 AM
  #38
Tedster9's Avatar
Tedster9
This would be an excellent excuse to order a case or two of Omaha steaks. They ship with blocks of dry ice, after all. When it shows up on the CC bill, just explain to wifey it's a "special tool" or "bushing installer". Thank me later.
Old Feb 14, 2016 | 11:24 AM
  #39
MIKES 68 F100
steel won't change with temperature of hot /even boiling water , but rubber/urethane will become more plyable instead of rock hard .
Old Feb 14, 2016 | 09:34 PM
  #40
orich's Avatar
orich
I'm not sure if, I understand what your saying Mike. As the way take what your saying is steel don't expand with any heat.
If this is the case then why is their a expansion joint on the rail road rails.
Or when your welding and the heat will pull two square pieces a part if parts are not tack first to hole them square.
But your a welder and know this that why I don't understand your statement
As it's always been heat the large part & chill the small ones.
Orich
Old Feb 14, 2016 | 09:47 PM
  #41
Randle's Avatar
Randle
Orich
That the way I've always done it. I grease the bushings and the spring eyes put a bolt with good heavy washers on both ends and draw them in with a impact, works as good as a press.
Old Feb 15, 2016 | 01:52 AM
  #42
JEFFFAFA's Avatar
JEFFFAFA
Not to beat you up Mike but seems to me boiling the bushings would expand them and make them kinda sticky. For poly anyways. If they run out of lube while being pulled in it wouldn't work. Just sayin' Buddy.
Old Feb 15, 2016 | 08:32 AM
  #43
MIKES 68 F100
didn't say boil bushings .
also water boils at 212f steel won't expand at this temp
I am done with this thread
Old Feb 16, 2016 | 01:25 AM
  #44
GaryKip's Avatar
GaryKip
I think what Mike was saying is that the warm water would make the bushings more pliable, instead of hard blocks at 10 deg. Just my 2cents.
Old Feb 16, 2016 | 07:34 AM
  #45
idealtrucks
Just to wrap the thread up, I tried some more and broke my piece of all thread, so I took them out to a local shop and used their press to get them in the rest of the way.
