2015+ F150 Discuss the 2015 Ford F150
Ford electric brake and plug
Old 04-23-2019, 01:59 PM
Lance Nelson
Lance Nelson is offline
Lance Nelson is starting off with a positive reputation.
Hello, I have a brand new 2016 left over F350 XL and a new dual axle 20 ft trailer with electric brakes. The problem is the trailer brakes only work when squeezing the controller manually, and never works when pressing the brake pedal. The guide/manual is very vague but it seems it should also work when braking with the truck brake pedal. Do I need a separate controller to make these trailer brakes work correctly, or should they be working with the stock set up? Thanks!
Old 04-23-2019, 03:19 PM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
GlueGuy has a great reputation on FTE.GlueGuy has a great reputation on FTE.GlueGuy has a great reputation on FTE.GlueGuy has a great reputation on FTE.GlueGuy has a great reputation on FTE.
Is the brake controller programmed into the console? Our F-150 will display the brake pedal %force when a trailer is connected. I would thnk the F350 would be real similar.
Old 04-23-2019, 03:39 PM
scott91370
scott91370 is offline
scott91370 has a good reputation on FTE.scott91370 has a good reputation on FTE.
Almost 3 year old NEW truck? I'm no help just thought - WOW!
Old 04-23-2019, 03:45 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is online now
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
Make sure your trailer brake settings are set for the brake type and your gain is adjusted.
Old 04-23-2019, 03:50 PM
Lance Nelson
I get no % on the dash at all when using the brake pedal, just when squeezing the manual controller I do. Not sure what you mean when you say programmed into the console? It doesnt come from dealer ready to go?
Old 04-23-2019, 05:00 PM
Lance Nelson
Brake setting is set to electric brakes and gain is adjusted to 8.5. Test Light shows no power to trailer plug brake wire when brake pedal is applied, but does have power when manually squeezed. I must be missing something
Old 04-23-2019, 05:51 PM
ecoboost12
ecoboost12 is offline
ecoboost12 has a good reputation on FTE.ecoboost12 has a good reputation on FTE.
Welcome to site have you tried the F-250 site they can answer your problems a great bunch of guys
Old 05-07-2019, 09:41 PM
Ken Newman's Avatar
Ken Newman
Ken Newman is offline
Ken Newman has a good reputation on FTE.Ken Newman has a good reputation on FTE.Ken Newman has a good reputation on FTE.
I recently added the Ford brake controller to my 2016 F150 and my friend hooked up his laptop to my truck an activated it. If I slide the brake lever over with no trailer connected, I get a chime and it shows no trailer connected on the dash display screen. I'm curious if you manually slide the brake lever over without a trailer connected, does it chime and give the warning? If not, I bet you need to activate it with the software. Good luck.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
