Sponsored by: Real Truck
Transmission line pressure
Old May 23, 2006 | 12:00 AM
modfan's Avatar
modfan
Can anyone tell me the trans line pressure on a 2006 F350 6.0L 5 speed auto out of the transmission.
Old May 23, 2006 | 12:32 AM
ford390gashog's Avatar
ford390gashog
about 150 psi.
Old May 23, 2006 | 06:59 AM
Casey's Avatar
Casey
Do you mean the pressure in the cooler lines? That will run up to about 60 PSI. Actual line pressure inside the trans can be up to 330 PSI.
Old May 23, 2006 | 05:50 PM
modfan's Avatar
modfan
Yes. The cooler lines. I was also wondering if the temp in the lines would ever reach 210 degrees. I know that the temp at 210 in the trans is not good. Thanks for the responce.
Old May 24, 2006 | 07:21 AM
Casey's Avatar
Casey
Yes, the temp in the cooler lines will go above 210°F. And that temp is not bad inside the trans, either.
Old May 25, 2006 | 12:30 AM
modfan's Avatar
modfan
Thanks for the help.
MoBill122
Nov 26, 2016 11:58 AM
mribbich
Jul 23, 2016 09:02 PM
Jon351m
May 14, 2015 03:09 PM
PEI
Mar 9, 2014 12:06 PM
waskin27
General Automotive Discussion
Jun 30, 2013 11:21 PM
