E150 van transmission codes
Old Jan 30, 2016 | 08:32 AM
Walt Bowers's Avatar
Walt Bowers
Hi. - new to the forum. I just got a well kept 2004 E-150 8 passenger van. I'm having trouble identifying the transmission code on the door jam sticker. my transmission code is a 5. I have searched thru lots of links for door jam sticker decoders and none of them list 5 as an option, but the ones I'm finding tend to reference the F-series truck but not the Econolines. Can someone point me in the right direction?
Thanks in advance.
Old Jan 30, 2016 | 10:12 AM
Conanski's Avatar
Conanski
Wow that is bizarre.. can't say I have ever seen that trans code. I ran a VIN decode and it was no help but other searches indicate it is likely a 4R70w or the slightly upgraded 4R75w, you can confirm that by having a look at the trans oilpan, if it looks like the pic below in shape then you know.
Old Jan 30, 2016 | 11:39 AM
Walt Bowers
That appears to be the pan I have. What is the difference between the 4R70 and 4R75?
This van is equipped with towing features like the super duty style mirrors, transmission cooler, engine oil cooler, Class 5 hitch.
Thanks for looking / responding!
Old Jan 30, 2016 | 03:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The difference between the 4R70 and 4R75 are internal and relatively minor. I never knew the specifics because I didn't work on these, but some parts are stronger in the 4R75.
The 75 part means the transmission is capable of handling 750 lb-ft of torque AFTER the torque converter. The 70 is capable of 700 lb-ft.
Old Feb 2, 2016 | 01:12 PM
Walt Bowers
OK, next question: In doing some reading I've discovered there is a shallow and deep transmission pan for this transmission, but I'm not sure how to tell which I have. The one I have looks similar in shape to the one above. It has the bulge. Has a big "S" on it and the word METRIC. Follow-up question: Who has installed a aftermarket deep pan / is it needed?
Old Feb 2, 2016 | 03:41 PM
Mark Kovalsky
An aftermarket deep pan is not needed. It has no benefit for the transmission, other than making the bottom of your van look pretty.
Old Feb 3, 2016 | 05:45 AM
Walt Bowers
Really? Thanks for the info. I don't want to be spending money on cosmetics - at least, not a transmission pan that will rarely seen. I am curious though - why wouldn't a deeper pan work? Especially one with cooling fins on the bottom? It makes sense to me, but I'm just learning. I guess a follow up question would be, is an upgraded transmission cooler from the factory external cooler money better spent. I'm asking because I do tow a boat. I know that keeping the transmission fluid cool is key, and I just wanted to know what, if any would be a good upgrade to the cooling when I change the transmission fluid. Thanks.
Old Feb 3, 2016 | 06:52 AM
Mark Kovalsky
It's hot under the van, how do you cool the transmission with hot air? And inside the pan there isn't a lot of flow, especially right at the pan surface. It's called the boundary layer. It acts like an insulator and keeps heat from escaping.
On the other hand a transmission cooler is up front where it gets cool air through the grill. This is how you cool a transmission.
Old Feb 19, 2016 | 07:57 AM
Walt Bowers
Thanks for the replies. New Question: Is there a Transmission temperature I can read via OBDII? I can find info on the F-150, but I'm having trouble finding references for the E-150's. Is the transmission the same between an F-150 & a E-150 (given they each have the same engine). I'm just hate to spend the money on a Scan gauge II to get Transmission temps if an UltraGauge will do just a well for the the standard parameters ( and be much cheaper)
Tim Foster
May 14, 2018 08:25 PM
fabchef
Mar 6, 2018 12:22 AM
MrNightman
Jun 29, 2015 07:45 AM
EmilBarnabas
Apr 21, 2012 09:58 PM
460MAGNUM
Feb 11, 2009 07:58 AM
