6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Whining sound in engine
Old Jan 30, 2016 | 04:35 AM
lilrams09's Avatar
lilrams09
Guys,
Yesterday I started my truck and I noticed a somewhat low pitch whine coming from under the hood. It did it at idle and if you give the truck a little gas you can hear it to. Once in drive it sounds like it goes away but between road and engine noise it's hard to tell. It sounds like it is coming from the passenger side. I popped the hood and it sounded like maybe a bearing on the alternator pulley but I can't pinpoint the noise. One time It sounds like it's coming out of the turbos, then you think it's up in the front of the motor.. I thought maybe even a bearing in the fan clutch. It's just hard to pin down a sound like that with all the sound coming from that motor.
Anyone else out there have a similar issue?
Old Jan 30, 2016 | 10:18 AM
fatboytx's Avatar
fatboytx
Google and you should find a video or two about failed 6.4 pulley. Then, go inspect your serpentine belt and tensioner pulley.
Old Jan 30, 2016 | 08:36 PM
lilrams09's Avatar
lilrams09
It was the alternator, it was darn near froze up... I hate to say it but it's sad that a truck with a $55k msrp has stuff like this fail at 75k miles!!! And then the fact that you have to rip half the front off the truck to get it out...
Old Jan 31, 2016 | 12:11 AM
73fan's Avatar
73fan
Well, 75K miles isn't that old, but at the same time, depending on the year of your truck, the alternator may be 8 years old.
As for changing it, I find it much easier to access by removing the right front wheel and inner fender.
Old Jan 31, 2016 | 07:53 AM
lilrams09's Avatar
lilrams09
That's what I did to pull it out. I ended up taking the air intake out also so it was easier to get the wires off and stuff. Everything in that truck is just packed in there and not practical to work on.
Old Feb 4, 2016 | 07:25 AM
ginomachino's Avatar
ginomachino
I find it a little comical when i hear people talk about engine compartment configurations. Compared to boats, vans, and some import L4 engines, these trucks are pretty easy to work on. No doubt, there are layers of components, but there is plenty of room to turn a wrench.
Old Feb 4, 2016 | 08:20 AM
lilrams09's Avatar
lilrams09
I can tell you I've never pulled the body off my eclipse or sti to change a fuel pump... Comical is saying these trucks are practical to work on.
Also I changed the alternator on my eclipse in about 15 minutes. Fact is these trucks are just not made for everyday people to get under and work on.
Old Feb 4, 2016 | 08:31 AM
ginomachino
eh, i guess it's just a matter of opinion. sure cars are easier to work on, but then they don't haul 15k pounds and they don't look as good either
Old Feb 5, 2016 | 01:46 AM
brandonrr's Avatar
brandonrr
My 2006 f250 6.0 can tow over 16k pounds legally and I changed my alternator in 10 minutes easily. It's right on top and couldn't be easier to swap out. I have a pet peeve with vehicles that have difficult to access alternators. My 2nd vehicle, an ugly old grocery getter saturn, is an american 4 cyl. It also has a hard to reach alternator. My brother has a 2006 tacoma, which also has a "well hidden" alternator. I used to sell new Volvos and it was the same story. I see no reason that most vehicles can't have a simple, easy to change alternator.
Okay, rant over.
Old Feb 5, 2016 | 07:51 AM
ginomachino
You can climb on top of, get to the sides of, slide underneath of the whole thing. it is what it is I say. it might be easy to change the alternator, but impossible to change the AC compressor. makes no difference to me which one is which lol
joeyd71
Mar 24, 2011 08:57 PM
Lennyg
1997 - 2003 F150
Apr 20, 2008 07:30 PM
blackthorne2
May 10, 2004 11:02 AM
diggbrd
1983 - 2012 Ranger & B-Series
Jan 11, 2004 07:37 AM
rusty68
Apr 18, 2001 12:52 PM
