1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Please help! Emergency, far from home, battery light
Old 01-29-2016, 11:30 PM
mountain dewd's Avatar
mountain dewd
mountain dewd is offline
Hello everybody,
Currently racing down to the Bay Area to a family emergency in our 2001 f250, 7.3 4x4. As we were driving down the highway, 75 mph or so, the battery light came on. We pulled over, tightened the battery terminals and began driving again. The light returned again. Stays solid for a bit, flickers, goes away, then comes back solid. Ammeter on the dash reads just past the middle on the higher side, regardless of the light being on or not. Please help, this is a life or death situation and we have to make it there. Thank you very much in advance.
Old 01-29-2016, 11:57 PM
Auminer's Avatar
Auminer
Auminer is offline
1) Crud on the battery terminals or connections.
2) Alt. or wiring to battery loose connections
Above all else check grounds!
Old 01-30-2016, 12:02 AM
Auminer's Avatar
Auminer
Auminer is offline
If your ammeter is reading good, you should be good to go. You are running a diesel and it ain't gonna quit on ya, but if your lights dim...
Old 01-30-2016, 12:04 AM
mountain dewd
Thank you so much for your help. Will check alternator wiring and grounds. Terminals are nice and clean.
Old 01-30-2016, 01:22 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
The battery light illuminated on modern trucks really means there is a problem with the alternator, it's probably not charging properly.
Old 01-30-2016, 02:05 AM
mountain dewd
Could be the alternator, as it is original. Problem appeared the day after having a diesel mechanic repair the clutch pedal.
Old 01-30-2016, 07:58 AM
allagash350's Avatar
allagash350
allagash350 is offline
Happened on my 02 before. Was alternator the batteries were still fine
Old 01-30-2016, 08:09 AM
The Bone's Avatar
The Bone
The Bone is offline
Check the connections at the starter. They could be lose. Everything runs through the starter.
Old 01-30-2016, 08:29 AM
Frantz's Avatar
Frantz
Frantz is offline
Step one of just about every repair is "remove negative battery terminal cable". I've been surprised in the past with how little visible dirt can cause a problem. I know you said you tightened em, but I'd take em off and really get int here good and make a good connection. If you have jumper cables, you can run one from the negative terminal to ground, and if the light goes away, then that cable is your problem at some point. Since the light has been somewhat intermittent then I'm more likely to believe a ground wire issue than a component issue.
Old 01-30-2016, 09:30 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Even better, run the cable to a clean, unpainted portion of the alternator itself. Good idea. This would be an indication that there are poor grounding and connections.
rthum45
6.4L Power Stroke Diesel
03-16-2019 11:40 AM
jatkins03
08-07-2017 04:26 PM
dblott1
01-05-2015 04:40 PM
tj0911
1997 - 2003 F150
12-13-2009 08:08 AM
SCOTTY STA-28
09-22-2009 12:01 PM
Quick Reply: Please help! Emergency, far from home, battery light
