Coolent Leak Can't find
I have a 1995 F-250 7.3, it started leaking coolent from what looked like the thermostat housing. So I replaced the o-ring and the neck that the top radiator hose connects to, yet it still leakes but not from that part. It seems to act like a gasket or o-ring problem because as soon as I drive it it warms up and stops leaking but as soon I shut off the engine its starts leaking again. Any help on locating this would be greatly appreciated.
F-250 7.3 Powerstroke
Mods: S and B Cold Air intake, Wicked wheel, 3 inch straight pipe
Another option is the thermostat housing flange ring - https://www.strictlydiesel.com/p-267...sing-ring.aspx . Comes with a new o-ring and MUCH higher quality bolts. Requires no messy Pizza Hut cheese (aka RTV).
I wonder if they gave the engineering job to a new grad/trainee. Such a simple part they figured no way to screw it up. Interesting how complicated stuff gets a lot of attention and sometimes the simple parts cause more trouble because no one really focuses on them.
Or, more likely, the accountants said that the original properly designed part was too expensive.
bdrummonds
72
03-07-2011 04:00 PM
matttaubert
11-03-2008 07:00 PM
