Official Ford Forum : Ask an Engineer Weekly Q&As with Ford Engineers!
F-150: Payload Capability
Old Feb 6, 2016 | 10:21 AM
johndeerefarmer's Avatar
johndeerefarmer
Originally Posted by seventyseven250
I can't speak for Ford from either a strategy or engineering standpoint, but I would guess that they have done the research as to what payload is required in the half-ton market, and they build to that. Reducing the weight of the body panels and then increasing the weight of the suspension to handle ~700lbs of additional payload would have eaten their lunch from a fuel economy perspective, and also probably gone into F250 territory from a capability perspective. I don't think they'd gain anything from that approach.
If the weight of the body is reduced by 700 lbs then you should be able to haul 700 lbs extra without making any changes to anything. You could get picky about it and make the payload only go up by the weight that the load over the rear axle was reduced.
The problem with Ford is their tow ratings. They talk about up to 12.2k lbs if properly equipped (with most 3.5 ecoboost trucks rated around 10,700 lbs). If you don't have the payload to go along with the tow ratings then the tow ratings are basically bogus.
I see no reason for having the GVWR reduced from 7700 lbs down to 7050 lbs. By doing this the 700 lbs that I could have gained in payload was reduced to only a 50 lb increase.
Old Feb 6, 2016 | 12:20 PM
T diesel's Avatar
T diesel
I don't think after viewing that video, ANYONE would think
that sag is acceptable, never-mind being proud of it.
Embarrassing!
Old Feb 6, 2016 | 03:30 PM
Skip1970's Avatar
Skip1970
it give the f150 that cartoon like hauling abulity, looks like something about to beak with wiley coyote driving off a cliff with too much acme dynomite in the back
Old Feb 8, 2016 | 12:46 PM
Ford Trucks's Avatar
Ford Trucks
Official Ford Trucks
Thanks for the additional discussion everyone, we'll send these further questions to the engineers to see what they have to say.
ArtsBest
2009 - 2014 F150
Feb 4, 2012 05:08 PM
Rusty_Old_F250
Aug 30, 2011 12:07 AM
FoMoCo86XL
Jul 14, 2004 11:56 PM
Zinfinity
Mar 31, 2003 01:02 AM
WQ59B
1997 - 2003 F150
Nov 8, 2001 08:05 AM
