rad hose leak
Old Jan 29, 2016 | 06:27 AM
granny_rocket's Avatar
granny_rocket
rad hose leak
Hey folks,
Shortly after replacing my water pump I discovered a coolant leak where the lower rad hose connects to the water pump. The hose itself is also new and I did not see any visual defects on the hose so I would like to assume it's ok.
Now that it's winter and freezing cold out I decided this would be a good time to fix it. (please note my sarcasm)...
The leak looks like the hose clamp isn't tight enough but I can assure you I've clamped it tight enough not to leak. The water/coolant is coming out from between the hose and the hose barb.
Has anyone seen a leak like this before? It's more of a dribble than anything but I don't want it to turn into something bigger when I decided to put the cooling system under duress. My first thought was maybe the casting of the water pump had a defect not causing the hose to seal? Anyone see something like this before? Thoughts on a fix that don't involved a water pump replacement? I was debating if I could use a little of that permatex gasket sealer (the black creosote looking sticky stuff that comes in a can with a brush) around the hose barb and iside of the hose? Or maybe some RTV? Thoughts?
Thanks Much,.
Old Jan 29, 2016 | 08:08 AM
oldbird1965's Avatar
oldbird1965
If it were me, I would move that clamp up and then put another clamp on it. I have double clamped hoses that don't want to stop leaking.
Old Jan 29, 2016 | 01:59 PM
97-psd's Avatar
97-psd
I wouldn't use any sealant on it. Either double clamp it and see if that solves it or pull it off, clean it, check it out, then reinstall. It sucks, sorry
Old Jan 29, 2016 | 05:04 PM
granny_rocket
Well thanks all. I hate to admit my faults but it's not the hose as I had thought. Since I had to pull the fan and shroud to replace the belt tensioner (separate project I had going) I got a much better look and VOILA....it is the nipple that connects the overflow tank hose to the water pump; It's loose.
What a dope I am. I used a nylon nipple, not thinking it would expand and contract, thus working itself loose enough to leak. I remember now I couldn't find a brass or steel one so I ran with the nylon one. Oh well, guess the tensioner needing replacement was a blessing in disguise (in more ways than one).
Wrench Bender 117
Nov 10, 2013 12:29 PM
GeneLaw1
Oct 16, 2012 09:42 PM
baby2000
20
Nov 14, 2009 08:38 AM
papadelogan
May 7, 2008 09:55 AM
scottlane
Nov 4, 2006 04:58 PM
