A cool running engine, answer to a question yet asked
Nothing is black and white and there are plenty of gray areas. There are many things that "work" today or even for years but are not right or even close to it.
All I ask is that people do their homework and check out the information at the library, from the SAE, and here on the boards from qualified sources.
For a start read SAE publication #HS-40/91, principles of engine cooling systems... Available from SAE ($50 for 49 pages) and possibly some large technical, or university libraries. I do not own a copy so all I can do is tell you what I read years ago in that or similar publications. The updated version is listed above.
You can find some limited information on automotive "tech info" pages. Many of them will flat out tell you not to run without a thermostat for many reasons. Unfortunately they do not give detailed reasons, you will need to read the many SAE publications for that.
I do always run a thermostat- but i am from Kansas City, where it does get cold in the winter- so i do believe in using the stat. And it is always a 160. The experience i have is from running these stats over the last 15 years, the last two years or so in my 96 Ranger 4.0.
Before that, growing up our 1948 John Deere "B" had no thermostat and always run 140 degrees, 150 if you really ran it wide open- i think we all already know how long running and how reliable J.D. tractors are! My model B is now a 1937 model, still does just fine and no stat.
Since this was my first EFI and computer equipped motor (my 96 Ranger- i even tried a 180 stat. The engine simply doesnt run as well. The gas mileage only improved 1 mpg from stock. Put in the 160 and presto! no more pinging, detonation, back firing- and a 4 mpg improvement from stock.
Here is my theory. I always also run electric fans. With a thermostat AND an electric fan- the stat is closed, and the fan is off when the engine is warming up- this condition allows it to warm up as quickly as possible- to get it out of open loop. Closed loop is 160 degrees, and you can verify this by going to www.slpengineering.com If you run a 160 stat, your water temp is going to be 170 degrees- i believe, just like Bronco351, that is the highest your water temp should ever get. Think about it- 170 degrees is actually very hot- be assured, there wont be acids forming. 170 degree water is plenty hot enough to get rid of any acids, just like it would get rid of the acid/oil in your driveway in fast order! I simply dont agree with the SAE guy- i use my own personal experience- i had a GMC S-15, 2.8 V-6 years ago. These engines were quite famous for blowing head gaskets, pinging, detonating, running very poorly. I checked the compression oon mine before i bought it- it was factory normal. After the 160 stat, electric fan, and radiator from a 4.3- ran like a champ!
Also 160 stats means your oil doesnt turn black nearly as fast, and the a/c blows far colder (If the underhood temp is around 230 vs. 170- your a/c just wont be nearly as good)
I suggest you actually install a 160 stat, and make sure your engine is running 170 degrees (i use mechanical water temp gauge #2333 from Auto Meter) check your gas mileage before and after- and just see yourself. Myself and Bronco351 have done this - and you see our report on doing it. The other poster hasnt even installed or ever used a 160 stat- i have for 15 years- let alone Bronco351. Now you can let us all know what you are going to do- J.D., KCK
Just a couple of questions. Why would researchers and engineers, of all car companies, put a thermostat in their cars and trucks, if they really didn't need one? Like was mentioned previously, a thermostat also helps warm an engine up faster and keep it warm in the winter by not letting water pass as quickly, thus you get heat from your heater. With a 4-row radiator I even use a blanket on mine in the winter to get a warm engine faster. I live in west TX and it gets pretty hot here also, but it gets cold too. I could see not having a thermostat in the summer, but never in the winter. Personally I wouldn't. I've also heard some people say running without a thermostat causes engines to overheat due to the constant flow, and the fluid doesn't have sufficient time to cool while passing through the radiator. (grant it this is not always going to be the case with every engine) Sort-of how an AC won't cool if the coolant doesn't have time to dissipate the heat from the inside coil to the exterior coil.
Please, no yelling! It's just another 2 cents.
The manufacturers primary concern is to get vehicles sold efficiently and cheaply. They mostly run 195 stats, imho, because they have to sell a vehicle equipped to run in Alaska as well as southern AZ. And they also mostly use mechanical fans, which are cheaper then electric fans and put out slightly more cooling effect.
If you run a 160 stat and you want heat in the winter- you are going to need an electric fan- which doesnt come on until the engine is hot- 170 degrees in my case. By the time the fan comes on- i already have plenty of heat. But if you run electric fans- even flex a lite's excellent Black Majic- you are going to need a bigger radiator then stock to keep your truck cool if you also use a/c and the temp is up around 100, which it is here in KCK.
Also 195 stats are a cheap way to meet emissions rules, again, esp when you are using a mechanical fan. Notice how Toyota and Honda, known for quite reliable vehicles- also use mostly 180 stats, not 195?? They take the time to fine tune the motor and meet emissions even with a 180 stat. 160 stats would be even better- but remember their vehicles have to run in Alaska too.
Basically- you as the owner of the vehicle have to fine tune it to work in the environment you use it in. And for most environments and with a broad range of temps- they run better with 160 stats, bigger radiators and electric fans. my 2 cents, but curious what others think. J.D., KCK
Well fellows I am about to test the theory (to some degree) weather or not the higher thermostat (higher than what I have now) makes any difference (usually someone would post the opposite wouldn't they?) using the stock recommended thermostat which is the 195 in my case. I am sure I will be posting questions about how my engine pings and the da*n thing won't start because of heat soak but what the he** i'm a gonna do it. I remember now why I thought the lower stat was a good idea, I was having trouble starting it hot, I installed the phenolic spacer and still had some problems but at this point I have a new HD radiator and covered the lines with heat tape as well an pulled them away from the block so hopefully the above were the solution and not the lower thermostat. Blah blah blah, I will let you all know something shortly
If someone has run a 160 stat for years and not had any "trouble", I am sure their "empirical data" is much better than hundreds of thousands of hours of specially instrumented research both in the lab and in the field, with all sorts of chemical and microscopic testing available. -The "color of the oil and the AC blows colder", -what a crock of BS.
Listen up guys... RUN THE FACTORY RECOMMENDED THERMOSTAT IN YOUR ENGINES!!! Absolutely NEVER run without one!!! -Unless of course you feel you are somehow smarter than 75 years of the cumulative efforts of thousands of Engineers and Scientists that work with these systems daily. Technology has changed and what may have "(barely kinda maybe) worked" 20 years ago is simply not acceptable today.
At the very MOST vary the temperature +/-10F from the factory recommendations due to climatic extremes. That DOES NOT apply to Kansas City, -I know I live there.
NASCAR engines run without a thermostat, they run a restrictor ring instead to modulate the flow of fluid thru the engine, -a special application under specific known heat loads. They change restrictors based on track temperatures etc.
The flow rate thru the radiator DOES influence the heat transfer rate. There is an optimum rate under certain conditions and the engineers working with computer simulations, instruments, and test engines have determined those rates. But then some people are smarter than all of that.
"Think about it- 170 degrees is actually very hot- be assured, there wont be acids forming. 170 degree water is plenty hot enough to get rid of any acids, just like it would get rid of the acid/oil in your driveway in fast order!"
Again "closed loop" is just an engine management computer setpoint that is used on some engines" that has no meaning in this topic. What does SLP Engineering have to do with the SAE and this conversation. They are an English Engineering construction company. Very strange reference??? A 1937/48 tractor motor does not have much to do with modern engines or engineering practice either.
As far as not running a 160 stat... Of that I am guilty but then I don't have to jump off a skyscraper either to know it is a very dumb idea. I have worked on engines with no stats and low temp stats and I CAN report accurately on the conditions I found in those engines.
I am done, I am thru arguing with ignorance and empiricle seat of the pants "data" from laymen with no scientific education... At some point you just have to let them baffle each other with BS!
The other post were the mention of not using a thermostat and/or using one as low as 160* falls into the GRAY area. Will it cause the engine to form acids that will deteriorate the engine, sure, but it also works for these people in the sense they achieve what they want and that is to not overheat their vehicle, if that is their decision, so what, you stated all you could.
Hey I read what you posted and apparently it made sense to me, my decision was not made only because of what you said. You mentioned something that I and others probably were not familiar with, I searched everywhere I could and gathered info compared it to yours and here I am I bought the d**n thermostat and hope to have it in shortly. I could run the thermostat at 160* get a little better air temperature in the intake or up the thermostat to the 195* and try and keep the motor as clean as possible, being as this vehicle is not driven often, this layman knows that is bad on a motor right off the bat so I opted for the latter, good choice huh. I was only going to let people know how the switch to the higher thermostat would affect my startup after the engine is warm as everyone knows that using edelbrock intake/carb it is possible to get heat soak. As stated before I think you have something to offer everyone as far as in depth technical support, it is the delivery, actually the final comments I cannot understand.
Now back on the subject.
YES, I do think I'm smarter than those scientists that do all that research in LABS. The reason I'm smarter is simple, I actually work on cars. I don;t sit in an office with a white coat on poking at chemicals. I'm in the garage getting greasy, and turning wrenches.
I forgot who stated that running with no thermostat creates too much flow through the radiator that, causes the fluid not to dissapate heat. This is a OLD wives tale. A cooling system acts on chain reactions. If the fluid in the radiator isn't moving (thermostat close/ open) fast enough, the fluid in the block also isn;t moving very fast. Which causes the fluid in the block to sit in one place WAY too long and create heat spots and possibly boil the fluid. If you don;t believe me go to any HIGH-Performance engine shop. They will are tell you the faster you get the coolant moving the cooler your engine will run!!!
Now as for NASCAR. The reason Nascar puts restriction plates in the cooling system is quite simple. They run very big water jackets throughout they're engiens. The purpose of the restriction plate is to create a small amount of pressure in the cooling system to keep the fluid moving properly.
The reason our cars/trucks don't have this problem when the thermostate is removed is because our cars/trucks use small water jackets/sharp bends in the water jackets, which casues coolant system pressure.
Now, the only time I use/suggest not to use a thermostat is in the peak summer months. In Arizona this is in JULY. Here in July the temp. can easily soar above 112*. Since I do heavy off-roading, and stop and go traffic. If it wasn't for no thermostat my engien would over-heat.
The rest of the year I run a 160* thermostat which keeps the cooling problems under control!!
I bet you I ****** off torque 1st again!!!
This IS my first EFI equipped vehicle with 160 stat. But i have 20,000 miles so far, never any pinging, gas mileage increase of 3 mpg., plugs are not black from over rich condition, no check engine light on. There is every sign that the engine is going to have a very long life, just like the GMC S-15 with the 160 stat before it did. And i believe in the 160 stat enough that i am willing to run the truck 10 years so i can find out. Thanks for your input- J.D., KCK
Also on the issue of oil color. The fact that the oil color doesn't change at 160°F indicates that the oil is not doing it's job. Oil does 3 things: lubricates, cools, and carries away contaminants. The color change is an indication of how well it is doing the latter.
On the issue of flow through a radiator, Heat exchangers require a certain residence time of the fluid in the exchanger to reject heat to atmosphere. If you pump the fluid through too quickly, it won't give up the heat
FWIW they're engineers at SAE not scientists, learn the difference. They spend more time working on and with engines than you can imagine.
