2010 Lariat heater switch problem
Jan 28, 2016 | 09:03 AM
My wife's 2010 Lariat, has a problem with the heater switch.
Its stuck in one speed.
Also the rear defogger switch doesn't light up. We don't know if the switch to it is just bad, OR if the whole system is bad.
Was also wondering if the blend door would be bad??
Anyone have a thought on this??
Thanx
Jan 28, 2016 | 11:36 AM
Quote:
Originally Posted by
Fat Ford Boy
My wife's 2010 Lariat....
....x
My 2012 Lariat rear defrost light would not light up (or work as a defroster) because the sliding rear window would not be recognized as being fully closed. The solution was to replace the entire rear window. Seems like this is not a rare situation, but I dont know if it applies to a 2010 Lariat (assuming you have a sliding rear window).
Jan 29, 2016 | 08:00 AM
Wife said the defrost switch came back on yesterday. I told her to tell them it is intermittent.
She is taking the truck in today, and set up an appointment, and get "their diagnosis, on the problems".
They told her the other day to just, "Drop it off, and we'll get to it in a couple of days". (I'd love to be there if they suggest that to her again).
There's another stealership close, if they give her any crap, that is where she will go !!
Stay tuned !!!
Jan 29, 2016 | 09:45 AM
Fat Ford Boy
Mine was intermittent, too. The sliding rear window contacts seem the be the culprit -
sometimes the sliding panel is considered fully closed=let defroster work
vs
its not considered closed=wont let defrost work.
At least in my case.
Jan 29, 2016 | 09:35 PM
O.K.The part that they replaced, was part # YH1829. It was a resistor.
I wasn't there, so I have no idea where it was, BUT wife says all is good.
The rear defroster now works.
We still have NO IDEA if there is a problem or not with the defroster. They said, that the thing was tested, and working fine.
Time will tell!!The part cost $79.38
Thanx, for all input. Hope this helps somewhere down the line.
Smokiesman
1997 - 2003 F150
Feb 22, 2018 12:52 PM
jvasqu
Jan 11, 2016 04:16 AM
shadows4
Aug 29, 2007 03:13 PM
jake00
Apr 13, 2005 10:58 PM
swenson
1978 - 1996 Big Bronco
Jun 10, 2002 09:57 PM
